Create precision work with the high-performance Dell UltraSharp U3014 monitor offering wide-ranging flexibility, efficiency and factory calibration. Designers, CGI animators, engineers, programmers, photographers and power users across many industries can benefit from high-end capabilities offered by the Dell UltraSharp U3014.
Connect to your external media with the flexible Dell UltraSharp U3014 monitor. This monitor offers multiple connectivity possibilities, mounting options and color settings, including daisy-chain connectivity for easy connections to multiple monitors.
Reduce the amount of time spent adjusting your screen and switching between applications with the enhanced capabilities of Dell Display Manager. This software application can help you get the most from your Dell UltraSharp monitor through Smart Video Enhance, Auto Mode and Easy Arrange functionalities.
You can help reduce energy costs and your impact on the environment with the Dell UltraSharp U3014 monitor. You also get the added benefit of PowerNap and Dynamic Dimming to help further reduce energy consumption.
Bring outstanding performance to demanding environments
Designers, CGI animators, engineers, programmers, photographers and power users across many industries can benefit from high-end capabilities offered by the Dell UltraSharp U3014. -
Get the flexibility to work the way you like
Connect to your external media with the flexible Dell UltraSharp U3014 monitor. This monitor offers multiple connectivity possibilities, mounting options and color settings, including daisy-chain connectivity for easy connections to multiple monitors. -
Simplify image management with Dell Display Manager
Reduce the amount of time spent adjusting your screen and switching between applications with the enhanced capabilities of Dell Display Manager. This software application can help you get the most from your Dell UltraSharp monitor through Smart Video Enhance, Auto Mode and Easy Arrange functionalities. -
Find more ways to save energy around your office
- Dell UltraSharp U3014 - LED monitor - 30"
- LED-backlit LCD monitor - 30"
- Energy Class
- Class C
- Energy Consumption per Year
- 82 kWh
- Power Consumption (On mode)
- 56 W
- Card reader, USB 3.0 hub
- Aspect Ratio
- 16:10
- Native Resolution
- 2560 x 1600 at 60 Hz
- Pixel Pitch
- 0.25 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 6 ms
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 120% (CIE 1976)
- Input Connectors
- HDMI, DVI-D, DisplayPort, Mini DisplayPort
- Height, swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 68.97 cm x 20.14 cm x 57.27 cm
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- EMC, CECP
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 82 kWh
- Diagonal Size
- 30"
- Viewable Size
- 29.77"
- Built-in Devices
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.25 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 120% (CIE 1976)
- Response Time
- 6 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- HDCP, PremierColor technology, PowerNap, Dynamic Dimming
- 68.97 cm x 20.14 cm x 57.27 cm - with stand
- DVI-D (dual link) (HDCP) , DisplayPort , Mini DisplayPort , 4 x USB 3.0 downstream , USB 3.0 upstream , HDMI , Audio line-out
Mechanical
- VESA Mounting Interface
- Security lock slot (cable lock sold separately), integrated cable management
- Included Accessories
- Stand, cable tie
- Cables Included
- 1 x USB cable , 1 x DVI cable , 1 x DisplayPort cable
- EMC, CECP
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 56 W
- Power Consumption (Typical)
- 60 Watt
- Power Consumption Stand by
- 0.98 Watt
- Power Consumption Sleep
- 0.3 Watt
- On / Off Switch
- No
- Included Software
- Drivers & Utilities
- Dimensions & Weight Details
- Without stand - width: 68.97 cm - depth: 6.1 cm - height: 44.92 cm - weight: 7.35 kg , With stand - width: 68.97 cm - depth: 20.14 cm - height: 57.27 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
