Dell U3014 30" 2560x1600 VGA DVI DP HDMI USB LED Monitor
Quicklinx: 9059WS00 Mfr#: 210-AAPI
Create precision work with the high-performance Dell UltraSharp U3014 monitor offering wide-ranging flexibility, efficiency and factory calibration. Designers, CGI animators, engineers, programmers, photographers and power users across many industries can benefit from high-end capabilities offered by the Dell UltraSharp U3014.
Connect to your external media with the flexible Dell UltraSharp U3014 monitor. This monitor offers multiple connectivity possibilities, mounting options and color settings, including daisy-chain connectivity for easy connections to multiple monitors.
Reduce the amount of time spent adjusting your screen and switching between applications with the enhanced capabilities of Dell Display Manager. This software application can help you get the most from your Dell UltraSharp monitor through Smart Video Enhance, Auto Mode and Easy Arrange functionalities.
You can help reduce energy costs and your impact on the environment with the Dell UltraSharp U3014 monitor. You also get the added benefit of PowerNap and Dynamic Dimming to help further reduce energy consumption.
  • Bring outstanding performance to demanding environments
  • Get the flexibility to work the way you like
  • Simplify image management with Dell Display Manager
  • Find more ways to save energy around your office
Dell UltraSharp U3014 - LED monitor - 30"
LED-backlit LCD monitor - 30"
Energy Class
Class C
Energy Consumption per Year
82 kWh
Power Consumption (On mode)
56 W
Card reader, USB 3.0 hub
Aspect Ratio
16:10
Native Resolution
2560 x 1600 at 60 Hz
Pixel Pitch
0.25 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
6 ms
Colour Support
1.07 billion colours
Colour Gamut
120% (CIE 1976)
Input Connectors
HDMI, DVI-D, DisplayPort, Mini DisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
68.97 cm x 20.14 cm x 57.27 cm
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
EMC, CECP
3-year warranty
Display Type
Energy Class
Class C
82 kWh
Diagonal Size
30"
Viewable Size
29.77"
Built-in Devices
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.25 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
120% (CIE 1976)
Response Time
6 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, PremierColor technology, PowerNap, Dynamic Dimming
68.97 cm x 20.14 cm x 57.27 cm - with stand
DVI-D (dual link) (HDCP) , DisplayPort , Mini DisplayPort , 4 x USB 3.0 downstream , USB 3.0 upstream , HDMI , Audio line-out
Mechanical
VESA Mounting Interface
Security lock slot (cable lock sold separately), integrated cable management
Stand, cable tie
1 x USB cable , 1 x DVI cable , 1 x DisplayPort cable
EMC, CECP
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
56 W
Power Consumption (Typical)
60 Watt
Power Consumption Stand by
0.98 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Included Software
Drivers & Utilities
Dimensions & Weight Details
Without stand - width: 68.97 cm - depth: 6.1 cm - height: 44.92 cm - weight: 7.35 kg , With stand - width: 68.97 cm - depth: 20.14 cm - height: 57.27 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
