Brand
Dell U2722DE 27" 2560 x 1440 8 ms QH LED monitor
Quicklinx: H0ZYWS00 Mfr#: DELL-U2722DE
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 5ms
Interfaces: HDMI, DisplayPort, USB-C
More than 50 In Stock
£324.46 ex VAT
£389.35 inc VAT
Elevate your productivity on this innovative monitor that delivers true-to-life color and seamless connectivity.
  • Designed with wellness in mind
    Optimize eye comfort with ComfortView Plus - an always on, built-in low blue light screen that reduces blue light emissions while delivering excellent color.
  • In-Plane Switching technology
    See consistent color and picture quality across a wide 178° / 178° viewing angle.
  • Seamless view
    Expand your view with virtually borderless InfinityEdge. With a four-sided, ultrathin bezel, you can work with a clear, edge-to-edge display. Use the daisy-chain feature for a seamless multimonitor setup.
  • Connect to productivity
    With RJ-45 and USB-C, your monitor serves as a productivity hub that delivers stable Ethernet and power.
  • Quick-access front ports
    Quick-access USB-C and SuperSpeed USB ports located at the front of the monitor enable fast connections to peripherals and mobile device charging.
  • Moves with you
    Adjust to your comfort with tilt, swivel, pivot and height adjustments for optimal viewing comfort.
Dell UltraSharp U2722DE - LED monitor - QHD - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class E
Power Consumption (On mode)
20.4 W
USB 3.2 Gen 2/USB-C hub, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
1.07 billion colours
Colour Gamut
100% Rec 709, 100% sRGB, 95% DCI-P3
Input Connectors
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
61.134 cm x 18.5 cm x 38.513 cm
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
Plug and Play, RoHS, NFPA 99, TUV Rheinland, BFR-free, DisplayPort 1.4, HDCP 1.4, PVC-free
Bundled Services
3 years Advanced Exchange Service
Latitude 5320, 5520; OptiPlex 3090; Precision 7560; XPS 13 9310, 15 9510
Display Type
Energy Class
Class E
Diagonal Size
27"
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
108.78
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
49 - 76 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Picture by picture, OSD lock, integrated cable management, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Low Blue Light technology, Delta E<2 calibration
61.134 cm x 18.5 cm x 38.513 cm - with stand
HDMI , DisplayPort 1.4 (HDCP 1.4) , DisplayPort output , USB-C 3.2 Gen 2 upstream , USB-C 3.2 Gen 2 downstream (power up to 15W) , 3 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out (mini-jack) , USB-C 3.2 Gen 2 upstream/DisplayPort 1.4 Alt Mode (power up to 90W) , Network (RJ-45)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x SuperSpeed USB cable - USB Type C to A - 1 m , 1 x USB-C to USB-C cable - 1 m
Security Slot Type
Kensington security slot
Input Voltage
20.4 W
20.4 kWh/1000h
Power Consumption (Typical)
20.4 Watt
Power Consumption (Max)
197 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 61.134 cm - depth: 18.5 cm - height: 38.513 cm , Without stand - width: 61.134 cm - depth: 4.95 cm - height: 35.201 cm - weight: 4.78 kg
Shipping Weight
10.01 kg
TCO Certified
ENERGY STAR Certified
Bundled Services
10 - 80% (non-condensing)
Dell Latitude 5320, 5520 , Dell OptiPlex 3090 , Dell Precision 7560 , Dell XPS 13 9310, 15 9510
Diagonal Size: 27in
Response Time: 5ms
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: USB-C
Brand: Dell
