Dell U2722DE 27" 2560 x 1440 8 ms QH LED monitor
Quicklinx: H0ZYWS00 Mfr#: DELL-U2722DE
Elevate your productivity on this innovative monitor that delivers true-to-life color and seamless connectivity.
  • Designed with wellness in mind
    Optimize eye comfort with ComfortView Plus - an always on, built-in low blue light screen that reduces blue light emissions while delivering excellent color.
  • In-Plane Switching technology
    See consistent color and picture quality across a wide 178° / 178° viewing angle.
  • Seamless view
    Expand your view with virtually borderless InfinityEdge. With a four-sided, ultrathin bezel, you can work with a clear, edge-to-edge display. Use the daisy-chain feature for a seamless multimonitor setup.
  • Connect to productivity
    With RJ-45 and USB-C, your monitor serves as a productivity hub that delivers stable Ethernet and power.
  • Quick-access front ports
    Quick-access USB-C and SuperSpeed USB ports located at the front of the monitor enable fast connections to peripherals and mobile device charging.
  • Moves with you
    Adjust to your comfort with tilt, swivel, pivot and height adjustments for optimal viewing comfort.
Dell UltraSharp U2722DE - LED monitor - QHD - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/414156
Energy Class
Class E
Power Consumption (On mode)
20.4 W
USB 3.2 Gen 2/USB-C hub, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
1.07 billion colours
Colour Gamut
100% Rec 709, 100% sRGB, 95% DCI-P3
Input Connectors
HDMI, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
61.134 cm x 18.5 cm x 38.513 cm
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
643 kg carbon emissions
Plug and Play, RoHS, NFPA 99, TUV Rheinland, BFR-free, DisplayPort 1.4, HDCP 1.4, PVC-free
3-year warranty
Bundled Services
3 years Basic Hardware Service with Advanced Exchange
Latitude 5320, 5520; OptiPlex 3090; Precision 7560; XPS 13 9310, 15 9510
Display Type
Energy Class
Class E
Diagonal Size
27"
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
108.78
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
49 - 76 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Picture by picture, OSD lock, integrated cable management, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Low Blue Light technology, Delta E<2 calibration
61.134 cm x 18.5 cm x 38.513 cm - with stand
HDMI , DisplayPort 1.4 (HDCP 1.4) , DisplayPort output , USB-C 3.2 Gen 2 upstream , USB-C 3.2 Gen 2 downstream (power up to 15W) , 3 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out (mini-jack) , USB-C 3.2 Gen 2 upstream/DisplayPort 1.4 Alt Mode (power up to 90W) , Network (RJ-45)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x SuperSpeed USB cable - USB Type C to A - 1 m , 1 x USB-C to USB-C cable - 1 m
Security Slot Type
Kensington security slot
Input Voltage
20.4 W
20.4 kWh/1000h
Power Consumption (Typical)
20.4 Watt
Power Consumption (Max)
197 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 61.134 cm - depth: 18.5 cm - height: 38.513 cm , Without stand - width: 61.134 cm - depth: 4.95 cm - height: 35.201 cm - weight: 4.78 kg
Shipping Weight
10.01 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
107
Manufacturing (kg CO2e)
378
Logistics (kg CO2e)
51
Use (kg CO2e)
210
EOL (kg CO2e)
3
Total Carbon w/o Use Phase (kg CO2e)
432
PAIA Version
1.2.13, 2021
Premium Panel Guarantee
Bundled Services
10 - 80% (non-condensing)
Dell Latitude 5320, 5520 , Dell OptiPlex 3090 , Dell Precision 7560 , Dell XPS 13 9310, 15 9510
Accessories (1)
H0ZY Dell Dual Monitor Stand - MDS19 In Stock £166.08
Other bundles (3)
H0ZY Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £26.91
H0ZY Dell SB521A Magnetic Sound bar In Stock £28.02
H0ZY Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £58.86
