Elevate your productivity on this innovative monitor that delivers true-to-life color and seamless connectivity.
Designed with wellness in mind
Optimize eye comfort with ComfortView Plus - an always on, built-in low blue light screen that reduces blue light emissions while delivering excellent color. -
In-Plane Switching technology
See consistent color and picture quality across a wide 178° / 178° viewing angle. -
Seamless view
Expand your view with virtually borderless InfinityEdge. With a four-sided, ultrathin bezel, you can work with a clear, edge-to-edge display. Use the daisy-chain feature for a seamless multimonitor setup. -
Connect to productivity
With RJ-45 and USB-C, your monitor serves as a productivity hub that delivers stable Ethernet and power. -
Quick-access front ports
Quick-access USB-C and SuperSpeed USB ports located at the front of the monitor enable fast connections to peripherals and mobile device charging. -
Moves with you
Adjust to your comfort with tilt, swivel, pivot and height adjustments for optimal viewing comfort.
- Dell UltraSharp U2722DE - LED monitor - QHD - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class E
- Power Consumption (On mode)
- 20.4 W
- USB 3.2 Gen 2/USB-C hub, USB PD 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (fast), 8 ms (normal)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% Rec 709, 100% sRGB, 95% DCI-P3
- Input Connectors
- HDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 61.134 cm x 18.5 cm x 38.513 cm
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
- Plug and Play, RoHS, NFPA 99, TUV Rheinland, BFR-free, DisplayPort 1.4, HDCP 1.4, PVC-free
- 3-year warranty
- Bundled Services
- 3 years Basic Hardware Service with Advanced Exchange
- Designed For
- Latitude 5320, 5520; OptiPlex 3090; Precision 7560; XPS 13 9310, 15 9510
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 27"
- Built-in Devices
- USB Power Delivery
- 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2331 mm
- Pixel Per Inch
- 108.78
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 49 - 76 Hz
- Horizontal Refresh Rate
- 30 - 90 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Picture by picture, OSD lock, integrated cable management, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Low Blue Light technology, Delta E<2 calibration
- 61.134 cm x 18.5 cm x 38.513 cm - with stand
- HDMI , DisplayPort 1.4 (HDCP 1.4) , DisplayPort output , USB-C 3.2 Gen 2 upstream , USB-C 3.2 Gen 2 downstream (power up to 15W) , 3 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out (mini-jack) , USB-C 3.2 Gen 2 upstream/DisplayPort 1.4 Alt Mode (power up to 90W) , Network (RJ-45)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x SuperSpeed USB cable - USB Type C to A - 1 m , 1 x USB-C to USB-C cable - 1 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- 20.4 W
- Power Consumption SDR (On mode)
- 20.4 kWh/1000h
- Power Consumption (Typical)
- 20.4 Watt
- Power Consumption (Max)
- 197 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 61.134 cm - depth: 18.5 cm - height: 38.513 cm , Without stand - width: 61.134 cm - depth: 4.95 cm - height: 35.201 cm - weight: 4.78 kg
- Shipping Weight
- 10.01 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Premium Panel Guarantee
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
- Designed For
- Dell Latitude 5320, 5520 , Dell OptiPlex 3090 , Dell Precision 7560 , Dell XPS 13 9310, 15 9510
Accessories (1)
Dell Dual Monitor Stand - MDS19 | In Stock | £149.14 |
Other bundles (3)
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £33.58 |
Dell SB521A Magnetic Sound bar | In Stock | £35.35 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £45.51 |
