Get a stable, wired connection to your network and peripherals on this sleek 23.8" QHD hub monitor with RJ45, USB-C and a host of other ports.
- Dell UltraSharp U2421HE - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class D
- Power Consumption (On mode)
- 12.9 W
- Daisy Chaining
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (fast), 8 ms (normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% Rec 709, 99% sRGB, 85% DCI-P3
- Input Connectors
- HDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 53.85 cm x 16.51 cm x 34.798 cm
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- RoHS, DisplayPort 1.4, HDCP 1.4
- Bundled Services
- 3 years Advanced Exchange Service
- Designed For
- Latitude 5320, 5520; Precision 7560; XPS 13 9310, 15 9510
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Daisy Chaining
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 92.5
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Delta E<2 calibration, 99% sRGB colour gamut
- 53.85 cm x 16.51 cm x 34.798 cm - with stand
- DisplayPort (HDCP) , HDMI (HDCP) , USB-C 3.1 Gen 1 upstream/DisplayPort Alt Mode with Power Delivery , DisplayPort output (MST) , 2 x USB 3.0 downstream , 2 x USB 3.0 downstream with Battery Charging 1.2 , Audio line-out (mini-jack) , LAN (RJ-45)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 80
- Height Adjustment
- 130 mm
- Security lock slot (cable lock sold separately), anti-theft stand lock slot
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x USB-C cable
- Input Voltage
- 12.9 W
- Power Consumption SDR (On mode)
- 12.9 kWh/1000h
- Dimensions & Weight Details
- With stand - width: 53.85 cm - depth: 16.51 cm - height: 34.798 cm , Without stand - width: 53.85 cm - depth: 3.81 cm - height: 31.496 cm - weight: 3.35 kg
- Shipping Weight
- 7.55 kg
- TCO Certified
- ENERGY STAR Certified
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
- Designed For
- Dell Latitude 5320, 5520 , Dell Precision 7560 , Dell XPS 13 9310, 15 9510
