Experience superb screen performance on this 23.8" monitor in an innovative, stylishly thin design with USB-C connectivity.
Impressive screen performance
Experience superb screen clarity with Full HD (1920x1080) resolution on a 23.8" screen. -
Color consistency comes standard
Your UltraSharp monitor is factory calibrated at 99% sRGB coverage to an accuracy of Delta-E less than 2, for precise hues right out of the box. Plus with 99% Rec709 and 85% DCI-P3 color coverage, you'll see true-to-life colors in video formats -
Always the best view
See consistent, vibrant colors across a wide viewing angle enabled by In-Plane Switching (IPS) technology. -
More room to work
With a stylishly thin panel profile (only 6.5mm at its thinnest) and a compact base that's approximately 30% smaller than its predecessori, you can free up valuable desk space. -
Adjust to your comfort
Pivot, tilt, swivel and adjust the height of your monitor for a comfortable setup all day long. Our improved design, with the hinge on the riser, makes it easier to adjust while keeping the riser in the same place. -
Clean and clutter-free
Focus on your work while hiding away cable clutter with an improved cable management design. -
All in one
Declutter your desk with the included USB-C cable, a single cable solution that transmits power, data, video and audio. -
Big convenience in one cable
Get an easy charge with USB-C, the same cable that connects your device to the monitor. Also, as you charge your PCs with up to 65W of power, protect it with Dell's built-in surge protection. -
Smooth transitions
Move from desk, to meeting and back again effortlessly with convenient, single cable connectivity via USB-C. -
Expand your efficiency
The virtually borderless design featuring InfinityEdge lets you enjoy a nearly seamless view of your content across multiple monitors. And, with dual monitors, you can increase your productivity by up to 18%. -
More ways to multitask
Easily organize multiple applications using predefined templates or a customized template with the Easy Arrange feature on Dell Display Manager software. Plus, you can conveniently tile your applications across a multi-monitor setup. -
Get right to work
With Auto-restore on Dell Display Manager, you can disconnect, reconnect and all of your applications will be in the same position where you left off.
- Dell UltraSharp U2419HC - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A+
- Energy Consumption per Year
- 22 kWh
- Power Consumption (On mode)
- 15 W
- Daisy Chaining
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (fast), 8 ms (normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% Rec 709, 99.9% sRGB, 85% DCI-P3
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 53.8 cm x 16.5 cm x 34.8 cm
- 7.55 kg
- Environmental Standards
- ENERGY STAR Qualified
- Carbon Footprint
- 549 kg carbon emissions
- RoHS, HDCP 1.4
- 3-year warranty
- Bundled Services
- 3-Years Advanced Exchange Service and Premium Panel Guarantee
- Designed For
- Latitude 7400 2-in-1; XPS 13 9380, 15 9570
- Display Type
- Energy Class
- Class A+
- 22 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Daisy Chaining
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 92.5
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- BFR/PVC-free, Mercury free, Dell Easy Arrange, arsenic free
- 53.8 cm x 16.5 cm x 34.8 cm - with stand
- 7.55 kg
- DisplayPort (HDCP) , DisplayPort output (MST) , HDMI (HDCP) , USB-C , 4 x USB 3.0 downstream (Type A) , Audio line-out (mini-jack)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 80
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support, anti-theft stand lock slot
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x USB-C cable
- RoHS, HDCP 1.4
- Security Slot Type
- Kensington security slot
- Input Voltage
- 15 W
- Power Consumption (Typical)
- 17.5 Watt
- Power Consumption Stand by
- 0.3 Watt
- On / Off Switch
- No
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10
- Dimensions & Weight Details
- Without stand - width: 53.85 cm - depth: 3.9 cm - height: 31.37 cm - weight: 3.37 kg , With stand - width: 53.8 cm - depth: 16.5 cm - height: 34.8 cm - weight: 7.55 kg
Sustainability Information
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 117
- Manufacturing (kg CO2e)
- 387
- Logistics (kg CO2e)
- 49
- Use (kg CO2e)
- 110
- EOL (kg CO2e)
- 3
- Total Carbon w/o Use Phase (kg CO2e)
- 439
- PAIA Version
- 9/5/2018
- Limited warranty - 3 years
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
- Designed For
- Dell Latitude 7400 2-in-1 , Dell XPS 13 9380, 15 9570
