Revel in the superior screen performance of the Dell UltraSharp 24 monitor, loaded with premium features for an exceptional viewing experience, without the premium price tag.
Position your monitor to comfortably fit the way you work with a full range of tilt, pivot, swivel and height adjustments along with easy connections to your PC and peripherals.
Your Dell UltraSharp 24 Monitor - U2415 is designed to be pixel perfect. That's why if you find even just one bright pixel, we'll replace it under the Premium Panel Guarantee.
World-class screen performance
Revel in the superior screen performance of the Dell UltraSharp 24 monitor, loaded with premium features for an exceptional viewing experience, without the premium price tag. -
Outstanding usability and connectivity
Position your monitor to comfortably fit the way you work with a full range of tilt, pivot, swivel and height adjustments along with easy connections to your PC and peripherals. -
Reliable and eco-efficient
Your Dell UltraSharp 24 Monitor - U2415 is designed to be pixel perfect. That's why if you find even just one bright pixel, we'll replace it under the Premium Panel Guarantee. -
Environmentally-conscious design
Made with eco-friendly materials, the U2415 is BFR/PVC-free (excluding external cables) and has arsenic-free glass and a mercury-free LED panel. Enhanced power management with PowerNap enables the Dell Display Manager to either dim the monitor to the minimum brightness level or put it into sleep mode when it is not in use.
- Dell UltraSharp U2415 - LED monitor - 24.1" - with 3-years Premium Panel Exchange service
- LED-backlit LCD monitor - 24.1"
- Energy Class
- Class A+
- Energy Consumption per Year
- 26 kWh
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey); 19 ms (black-to-white)
- Colour Support
- 16.8 million colours
- Input Connectors
- 2xHDMI (MHL), DisplayPort, Mini DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Black
- 53.22 cm x 20.5 cm x 40.29 cm
- 6.35 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TCO Displays
- 3 years warranty
- Bundled with
- 3-years Premium Panel Exchange service
- Display Type
- Energy Class
- Class A+
- 26 kWh
- Diagonal Size
- 24.1"
- Viewable Size
- 24.1"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, sharpness, saturation, gamma correction, rotation, input select, colour temperature, hue, aspect control
- LED edgelight system, stand lock, 99% sRGB colour gamut, Multi-Stream transport (MST), BFR/PVC-free, Energy Gauge, Energy Saver, Premium Panel Guarantee, 91% (CIE 1976) colour gamut, 76% (CIE 1931) colour gamut, High Bit Rate 2 (HBR2)
- Black
- 53.22 cm x 20.5 cm x 40.29 cm - with stand
- 6.35 kg
- Bundled with
- 2 x MHL / HDMI , DisplayPort output (MST) , Mini DisplayPort , 5 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out , DisplayPort
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 115 mm
- Flat Panel Mount Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), LED indicator, integrated cable management
- Included Accessories
- Stand, cable management cover
- Cables Included
- 1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 65 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 53.22 cm - depth: 20.5 cm - height: 40.29 cm - weight: 6.35 kg , Without stand - width: 53.22 cm - depth: 4.57 cm - height: 35.06 cm - weight: 4.25 kg
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £96.99 | in stock |
£296.88
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G 0.5m Select High Speed HDMI with Ethernet | In Stock | £6.46 |
C2G 5m Select High Speed HDMI with Ethernet | In Stock | £21.58 |
C2G 10m Select High Speed HDMI with Ethernet | In Stock | £41.46 |
C2G 15m Select High Speed HDMI with Ethernet | In Stock | £56.17 |
C2G Pro HDMI to VGA Converter | In Stock | £51.78 |
C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black | In Stock | £14.57 |
