Dell Thunderbolt Dock WD22TB4 180W
Quicklinx: H5XMWS00 Mfr#: DELL-WD22TB4
£241.39 ex VAT
£289.66 inc VAT
The Dell WD22TB4 docking station is a comprehensive solution for expanding your laptop's connectivity and functionality. Designed to meet the needs of professionals and enthusiasts alike, it features a robust set of interfaces including dual DisplayPort, HDMI, and Thunderbolt ports, allowing for the connection of multiple high-resolution displays. This port expansion powerhouse doesn't stop at video; it also includes a variety of USB ports, supporting both USB 3.2 Gen 1 and Gen 2 devices for fast data transfer and efficient charging.
In addition to its impressive display and USB capabilities, the WD22TB4 offers superior network connectivity options with its RJ-45 connector, supporting Ethernet speeds up to Gigabit Ethernet for fast and reliable Internet access. Security is also a priority, with both Noble Wedge and Kensington security slots available to protect your investment. Lastly, its efficient power management system, including a 130 Watt power adapter, ensures your devices stay charged without excessive energy consumption. Whether for work or play, the Dell WD22TB4 docking station is an essential tool for enhancing your digital experience.
  • Versatile connectivity
    Equipped with dual DisplayPort, HDMI, and Thunderbolt interfaces, the Dell WD22TB4 docking station offers a variety of display options, supporting up to a 5120 x 2880 resolution at 60 Hz for crisp, clear visuals on multiple screens.
  • Comprehensive USB support
    With three USB 3.2 Gen 1 Type-A ports and two USB-C 3.2 Gen 2 ports, this docking station provides ample connectivity for all your peripherals, ensuring fast data transfer and efficient device charging.
  • Enhanced network performance
    Featuring an RJ-45 connector supporting Ethernet, Fast Ethernet, and Gigabit Ethernet, the Dell WD22TB4 ensures reliable, high-speed network connections for uninterrupted work and play.
  • Secure docking
    The inclusion of both Noble Wedge and Kensington security slots provides flexible security options, helping to keep your docking station safe in public or high-traffic environments.
  • Efficient power management
    With a power adapter that delivers up to 130 Watts, this docking station efficiently powers and charges your devices, while its maximum power consumption of 180 Watts ensures it meets energy efficiency standards.
Dell WD22TB4 - docking station - Thunderbolt - DP, Thunderbolt, HDMI - 1GbE
Docking station
Docking Interface
Thunderbolt
Video Interfaces
20.5 cm x 9 cm x 2.9 cm
650 g
Gigabit Ethernet
Power adapter 180 Watt AC 120/230 V (50/60 Hz) 130 Watt Power Provided
Pricing Type
Brown Box
3-year warranty
Docking station
20.5 cm
9 cm
2.9 cm
650 g
Video
Max Resolution Details
5120 x 2880 - 60 Hz
2 x display / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB-C / DisplayPort , 3 x USB 3.2 Gen 1 - 9 pin USB Type A , 2 x USB-C 3.2 Gen 2 , 1 x network - Ethernet 1000 - RJ-45
Security Slot Type
Noble Wedge security slot / Kensington security slot
DisplayPort 1.4
Pricing Type
Brown Box
Power adapter
Power Consumption (Max)
180 Watt
Power Provided
130 Watt
Windows 10, Windows 11, Ubuntu 20.04 or later
Limited warranty - 3 years
H5XM Dell Dell Speakerphone SP3022 In Stock £50.73
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: H5XM 051363
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £171.53
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Dell
Stock Status: Used Stock
