Dell T3620 Core i7-6700 8GB 1TB Quadro K420 Windows 7 Pro
Quicklinx: CQSXWS00 Mfr#: 3PRKK
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
Affordable tower Workstations for professional performance. Fully configurable and ISV certified with Intel processors and discrete graphics.
Fast is an understatement: Power through intensive tasks easily thanks to the new 6th Gen Intel Core i and Xeon E3-1200 V5 processors enabled for fast and stable performance. Now including Intel Core i7-6700K Processor options with faster turbo frequencies.
For the professional: Experience powerful graphics options including AMD FirePro or NVIDIA Quadro professional-grade discrete graphics for even the most demanding projects.
Independent Software Vendor (ISV) certification: Dell Precision Workstations are tested to ensure the high-performance applications you rely on every day run smoothly. Dell ISV-certifications cover the most popular independent software applications.
Reach maximum potential: The Dell Precision Optimizer, with SCCM centralized management, improves productivity and performance by fine-tuning your system beyond standard factory settings, and optimizes certified ISV apps.
The small form factor tower workstation is the industry's most compact small form factor design. The optional Platinum-rated PSU has a smaller design that leaves a reduced environmental footprint.
The smallest mini tower workstation on the market. The compact size with the option to expand as your business needs grow makes this ideal for maximum space saving without sacrificing power or potential.
Supreme security: You can choose your level of security with a number of beneficial options including: Optional Dell Data Protection , Security Tools + Dell ControlVault , Encryption Personal Edition or Enterprise Edition.
Massive memory: Easily store and access large and complex 3D, multimedia and video project files with the speed and reliability of up to 64GB2 of DDR4 2133 MHz memory.
Lock and key: Available FIPS certified self-encrypting drives (SEDs) can reduce security risks and unauthorized access to your data.
Big files? No problem: Large file transfers of data and video are quick and easy with Thunderbolt 2 connectivity as well as optional PCIe M.2 SSD storage.
  • Powerful performance
    Fast is an understatement: power through intensive tasks easily thanks to the vigorous processors enabled for fast and stable performance.
  • Your work can count on it
  • Reach maximum potential
    The Precision Optimizer, with SCCM centralized management, improves productivity and performance by fine-tuning your system beyond standard factory settings, and optimizes certified ISV apps.
  • Small form factor
  • Massive memory
    Easily store and access large and complex 3D, multimedia and video project files with the speed and reliability.
Dell Precision Tower 3620 - MT - Core i7 6700 3.4 GHz - vPro - 8 GB - HDD 1 TB
Workstation - mini tower
Platform Technology
Intel vPro Platform
1 x Intel Core i7 (6th Gen) 6700 / 3.4 GHz (, up to 4 GHz, (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 1 TB - SATA - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
NVIDIA Quadro K420
Video Memory
2 GB
Audio Output
Stereo
1GbE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition + Windows 10 Pro 64-bit Licence
17.5 cm x 43.5 cm x 36 cm
Pricing Type
Build To Plan (BTP)
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - response time: next business day
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
Mini tower
Processor / Chipset
CPU
Clock Speed
3.4 GHz
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel C236
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 64 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD-Writer
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
NVIDIA Quadro K420
Video Memory
2 GB
Audio Output
Sound Output Mode
Stereo
High Definition Audio
Input Device
Mouse (on selected markets only), keyboard (on selected markets only)
Keyboard
Keyboard Name
Dell KB216 Wired Keyboard
USB
Mouse
Mouse Name
Dell MS116 USB Optical Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
Bays
Internal 4x2.5" / 2x3.5" shared , 2 external 5.25" x 1/2H
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x DIMM 288-pin , 1 PCIe 3.0 x16 - full-height , 1 PCIe 3.0 x16 - full-height (x4 mode) , 1 PCIe 3.0 x1 - full-height , 1 PCI - full-height , 1 M.2 Card
4 x USB 2.0 (2 front, 2 rear) , 6 x USB 3.0 (2 front, 4 rear) , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in/microphone (1 rear) , 1 x audio line-out (1 rear)
GS, CECP
Pricing Type
Build To Plan (BTP)
Power supply
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition + Windows 10 Pro 64-bit Licence - Multilingual User Interface (MUI)
Sustainability Information
ENERGY STAR Certified
17.5 cm
43.5 cm
36 cm
