Experience great audio clarity with this Teams certified wired headset that provides convenient call controls at your fingertips.
Great acoustic quality
Listen to speakers, attend lessons and participate in discussions with sound quality you can rely on; complete with great voice pick-up to ensure you are heard clearly. -
Plug in from anywhere
Directional, noise-canceling mic reduces background noise while speaking, allowing learners to participate in conversations from any environment. -
Ideal for learning
Are you looking for a high-quality, reliable and comfortable headset so your sole focus can be on your education? This Dell Stereo Headset is perfect for you.
- Dell Stereo Headset WH1022 - headset
- Product Type
- Headset - wired - USB
- Compatibility
- Linux, Mac, Windows
- Recommended Use
- Computer
- Connectivity Technology
- Wired
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Microphone
- Boom
- Microphone Noise Cancelling
- Controls
- Volume, microphone on/mute
- 3-year warranty
- Product Type
- Compatibility
- 18.1 cm
- 5.2 cm
- 18.6 cm
- 121 g
- Earpad Material
- Leatherette
- Recommended Use
- Computer
Audio Output
- Wired
- 20 - 20000 Hz
- In-Cord Volume Control
- Adjustable Headband
Microphone
- Boom
- 150 - 7000 Hz
- Noise Cancelling
- Adjustable structure
Remote Control
- Controls
- Connector Type
- USB 2.0 (4 PIN USB Type A) , Audio line-in
Cable
- Cable Length
- 1.5 m
- Cable Details
- USB cable
- Limited hardware warranty - advanced exchange programme - 3 years
