Dell SonicWALL TZ 105 Wireless-N - Security Appliance
Quicklinx: 8NPQWS00 Mfr#: 01-SSC-4899
  • IEEE 802.11n
The Dell SonicWALL TZ 105 is the secure Unified Threat Management (UTM) firewall available for small offices, home offices and small retail deployments. Unlike consumer-grade products, the TZ 105 delivers the proven, most effective intrusion prevention, anti-malware and content/URL filtering, along with the broad mobile platform support for laptops, smartphones and tablets. It provides full deep packet inspection (DPI) at very high performance levels, eliminating the network bottleneck that other products introduce, and enabling organizations to realize increased productivity gains without the increased cost.
  • High-performance security engine
    The SonicWall TZ 105 uses Reassembly-Free Deep Packet Inspection to examine traffic simultaneously across all ports without introducing latency to the network, enabling businesses to realize increased productivity gains.
  • Integrated intrusion prevention
    A tightly integrated intrusion prevention engine protects against a comprehensive array of application-layer exploits that target both servers and client machines on the network.
  • Advanced IPSec and SSL VPN
    Flexible connectivity options provide easy-to-use, secure, high-speed office-to-office and client-to-office remote access. With IPSec VPN, users can also connect with a Global VPN Client.
  • Streamlined GUI and advanced management
    Intuitive set-up wizards and a powerful web interface ease deployment, simplify configuration, and streamline management to reduce administration time and costs.
SonicWall TZ 105 Wireless-N - security appliance - Wi-Fi
Security appliance
External
RAM
256 MB
Flash Memory
32 MB
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Performance
Stateful throughput: 200 Mbps , Gateway anti-virus throughput: 40 Mbps , IPS throughput: 60 Mbps , Unified Threat Management (UTM) throughput: 25 Mbps , VPN throughput (3DES/AES): 75 Mbps , Connection rate: 1000 connections per second
Connection / user qty: 8000 , VPN tunnels (site-to-site): 5 , SSL VPN peers: 1 , Nodes: unlimited , DPI connections: 8000 , Authenticated users (internal database): 150
VoIP Protocols
SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2, H.323 v5
19 cm x 14.1 cm x 3.6 cm
380 g
Security appliance
19 cm
14.1 cm
3.6 cm
380 g
Processor / Memory / Storage
RAM
256 MB
Flash Memory
32 MB
External
Wireless, wired
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
Routing Protocol
OSPF, RIP-1, RIP-2, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, HTTP, HTTPS, CLI
Performance
Status Indicators
Power, link OK, test mode
Firewall protection, routing, NAT support, VPN support, PAT support, load balancing, VLAN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, dynamic DNS server, antivirus analysis, Intrusion Prevention System (IPS), Deep Packet Inspection (DPI), DDos attack prevention, anti-spam protection, IPSec NAT-Traversal (NAT-T), RADIUS support, DHCP server, bandwidth control, anti-spyware protection, NetFlow
Encryption Algorithm
DES, Triple DES, MD5, SHA-1, PEAP, TTLS, TKIP, WPA, WPA2, WPA-PSK, 128-bit AES, 256-bit AES
Authentication Method
RADIUS, LDAP, Active Directory, XAUTH authentication
IEEE 802.11b, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n
IP Telephony
VoIP Protocols
Aerial
Antenna
External detachable
Antenna Qty
2
5 x 100Base-TX - RJ-45 , 1 x management - RJ-45 , 1 x USB - Type A
FCC Class A certified, UL, TUV GS, VCCI, C-Tick, ICSA Firewall certified, cUL, NOM, CB, FIPS 140-2 Level 2, MIC, RoHS, WEEE, EAL 4+, VPNC certified, IPv6 Ready
External power adapter
7 Watt
5 - 95% (non-condensing)
8NPQ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.68
8NPQ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.87
