The Dell External USB Slim DVD +/ - RW Optical Drive is a plug and play disc burning and disc playing solution that you can use with a USB port.
 - Dell Slim DW316 - DVD±RW (±R DL) / DVD-RAM drive - USB 2.0 - external
 - DVD±RW (±R DL) / DVD-RAM drive - external
- Interface
 - USB 2.0
 - 14.4 cm x 13.75 cm x 1.4 cm
 - 200 g
- Optical Storage
- Read Speed
 - 24x (CD) / 8x (DVD)
- Write Speed
 - 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
- CD / DVD Rewrite Speed
 - 24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
- Buffer Underrun Protection
 - Automatic Buffer Under Run Error Protection Technology
- Media Load Type
 - Tray
 - 1-year warranty
- Interface
 - USB 2.0
 - 14.4 cm
 - 13.75 cm
 - 1.4 cm
 - 200 g
Optical Storage
- Read Speed
- Write Speed
- Supported Media Formats
 - CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM, DVD-Video, DVD-Audio, Super Video CD, Super Audio CD Hybrid Disc
- Supported Media Types
 - CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL, M-DISC
- Media Load Type
 - Tray
- Buffer Size
 - 0.75 MB
 - Emergency disc eject hole, Active Optimum Power Control (AOPC), CPRM support
 - 1 x USB 2.0
- Cables Included
 - 1 x USB cable - external - 60 cm
- MTBF
 - 150,000 hour(s)
 - Plug and Play
- Software Included
 - CyberLink Media Suite CD
 - Limited warranty - 1 year
 - 5 °C
 - 40 °C
 - 15 - 85% (non-condensing)
- Sound Emission
 - 50 dBA
