The Dell MSA14 single monitor articulating arm is designed to maximize your viewing comfort and improve your productivity with its multi-adjustment capabilities such as height adjustability, tilt, and swivel and pivot features. It can easily be attached to Dell monitor panels with a simple snap to the VESA mount at the back of the monitor without the need for screws. By replacing the standard monitor base with an articulating Dell monitor arm, the space directly in front of the monitor is recovered and you will not need to strain to access work space on the desktop. When properly positioned, Dell monitor arm with integrated cable management feature, keeps your desktop neat, offering both enhanced ergonomics and improved space utilization.
- Dell MSA14 Single Monitor Arm Stand mounting kit - for LCD display - black
- Product Type
- Mounting kit - desktop
- Mounting Components
- Articulating arm, VESA adapter plate
- Adjustments
- Tilt
- Recommended Use
- LCD display
- Recommended Display Size
- 19"-38"
- VESA Mounting Interface
- Black
- Designed For
- Dell D2015, E1916, E2016, E2216, E2316, E2416, P2016, P2212, P2213, P2214, P2415, P2715; Latitude 13 7350, 7275, 7370, E5250, E5270, E5440, E5450, E7250, E7270, E7450; OptiPlex 9010; Precision 3510, 5510, 7510, 7710; Precision Tower 3620, 5810, 7810, 7910; UltraSharp U2417, U2515, UZ2315, UZ2715
- Black
AV Furniture
- Mounting kit
- Recommended Use
- LCD display
- Placing / Mounting
- Desktop
- Cable Management
- Integrated cable management
- 19"-38"
- Adjustments
- Tilt
- Adjustable height, portrait to landscape movement, swivel adjustment
- Designed For
- Dell D2015H, E170S, E1713S, E1909W, E190S, E1911, E1912H, E1913, E1913S, E1914H, E1916H, E2009W, E2011H, E2013H, E2014H, E2015HV, E2016, E2210, E2211H, E2213, E2213H, E2214H, E2215HV, E2216h, E2311H, E2313H, E2314H, E2316H, E2414H, E2416H, P2011H, P2012H, P2014H, P2016, P2210, P2210H, P2211H, P2212H, P2213, P2214H, P2311H, P2312H, P2314H, P2314T, P2411H, P2412H, P2414H, P2415Q, P2715Q, P2815Q , Dell Latitude 13 7350, 7275, 7370, E5250, E5270, E5440, E5450, E5540, E7250, E7270, E7450 , Dell OptiPlex 9010 All In One , Dell Precision 3510, 5510, 7510, 7710 , Dell Precision Tower 3620, 5810, 7810, 7910 , Dell Professional P170S, P190S, P1911, P1913, P1913S, P1914S, P2714H, P2714T , Dell UltraSharp 1908FP, 1909W, 2007FP, 2009W, 2408WFP, U2211H, U2212HM, U2311H, U2312HM, U2410, U2412M, U2413, U2414H, U2415, U2417HJ, U2515H, U2711, U2713H, U2713HM, U2715H, U2913WM, U3011, U3014, UP2414Q, UP3214Q, UZ2215H, UZ2315H, UZ2715H
