Maximize your workspace with the Dell E-Port II Replicator. This E-Port Replicator gives you a comfortable work space where you can plug a keyboard, mouse and monitor to the port replicators and use your laptop like a desktop! Simplified connectivity facilitates a single interface to connect to your printer, monitor or other peripheral devices.
- Dell E-Port II Simple - port replicator
- Product Type
- Port replicator
- 20 cm x 17 cm x 5.37 cm
- 780 g
- Localisation
- United Kingdom, Ireland
- Power
- Power adapter - external 130 Watt Power Provided
- Designed For
- Latitude 2120, 6430u, E5250, E5270, E5420, E5430, E5440, E5450, E5520, E5530, E5540, E5550, E5570, E6230, E6320, E6330, E6420, E6420 ATG, E6420 XFR, E6430, E6430 ATG, E6430S, E6440, E6520, E6530, E6540, E7240, E7250, E7270, E7440, E7450, E7470, XT3
- Product Type
- Port replicator
- 20 cm
- 17 cm
- 5.37 cm
- 780 g
- Localisation
- 1 x headphones - output - mini-phone 3.5 mm , 1 x microphone - input - mini-phone 3.5 mm , 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x display / video - DVI-Digital - 24+1 pin digital DVI , 1 x network - Ethernet - RJ-45 , 1 x display / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x eSATA / USB 2.0 - 11 pin USB/eSATA , 3 x USB 2.0 - 4 pin USB Type A , 1 x monitor stand port
- Power Device
- Power Provided
- 130 Watt
- Designed For
- Dell Latitude 2120, 6430u, E5250, E5270, E5420, E5430, E5440, E5450, E5520, E5530, E5540, E5550, E5570, E6230, E6320, E6330, E6420, E6420 ATG, E6420 XFR, E6430, E6430 ATG, E6430S, E6440, E6520, E6530, E6540, E7240, E7250, E7270, E7440, E7450, E7470, XT3
C2G 2m DisplayPort Male to HD Male Adapter Cable - Black | In Stock | £25.26 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
