The Dell SE2425HM is a 24-inch desktop monitor designed to deliver a vivid viewing experience. With a native resolution of 1920 x 1080 and a pixel pitch of 0.2745 mm, this monitor offers clear and sharp images, making it suitable for various applications from gaming to productivity. Featuring an anti-glare coating and flicker-free technology, it minimizes eye strain during extended use while Dell ComfortView Plus further enhances the viewing experience by reducing harmful blue light emissions. The monitor boasts a wide horizontal and vertical viewing angle of 178 degrees, ensuring that colors remain consistent from different perspectives. A tilt adjustment range of -5 to +21 degrees provides flexibility for comfortable viewing angles. With HDMI and VGA input options, connectivity is straightforward. Additionally, the energy-efficient design is ENERGY STAR certified, affirming its commitment to environmentally sustainable performance while providing a vibrant display with 16.7 million colors available to enhance multimedia content.
Vivid display quality
With a native resolution of 1920 x 1080, the Dell SE2425HM provides exceptional image clarity, making it suitable for entertainment, work, and creative tasks. -
Eye comfort technology
Features like Dell ComfortView Plus and flicker-free technology help reduce eye strain during long hours of use, ensuring a comfortable viewing experience. -
Versatile connectivity
Equipped with HDMI and VGA connections, this monitor allows for easy integration with a variety of devices, making it an excellent choice for any setup. -
Adjustable viewing angles
The tilt functionality provides the ability to customize the monitor’s angle for enhanced comfort and improved ergonomics. -
Environmentally friendly
Designed with sustainability in mind, this monitor is ENERGY STAR certified and incorporates materials aimed at reducing its environmental impact.
- Dell SE2425HM - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/2192908
- Energy Class
- Class D
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 (VGA: 60 Hz, HDMI: 100 Hz)
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC (CIE 1931)
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 100-240 V (50/60 Hz)
- 53.864 cm x 17.881 cm x 41.226 cm
- 3.47 kg
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
- Carbon Footprint
- 141 kg carbon emissions
- Plug and Play, RoHS, NFPA 99, HDCP 1.4, BFR-reduced, PVC-reduced, TUV Rheinland Eye Comfort Certification (3-star)
- Bundled Services
- 3 years Basic Hardware Service with Advanced Exchange
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 50 - 100 Hz
- Horizontal Refresh Rate
- 30 - 110 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Eye comfort mode, 3-sided bezeless, Dell ComfortView Plus
- 53.864 cm x 17.881 cm x 41.226 cm - with stand
- 3.47 kg
- HDMI (HDCP 1.4) ¦ VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support, cable management system
- Cables Included
- 1 x HDMI cable - 1.8 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 13 kWh/1000h
- Power Consumption (Typical)
- 12.11 Watt
- Power Consumption (Max)
- 28.5 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 53.864 cm - depth: 17.881 cm - height: 41.226 cm - weight: 3.47 kg , Without stand - width: 53.864 cm - depth: 4.77 cm - height: 32.421 cm - weight: 2.8 kg
- Shipping Weight
- 5.01 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Carbon Footprint
- Manufacturing (kg CO2e)
- 66.27
- Logistics (kg CO2e)
- 9.45
- Use (kg CO2e)
- 63.17
- EOL (kg CO2e)
- 1.97
- Total Carbon w/o Use Phase (kg CO2e)
- 77.83
- PAIA Version
- GaBi version 1
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
