Dell SE2425HM 24" 1920x1080 5ms VGA HDMI IPS LED Monitor
Quicklinx: J71XWS00 Mfr#: SE2425HM
The Dell SE2425HM is a 24-inch desktop monitor designed to deliver a vivid viewing experience. With a native resolution of 1920 x 1080 and a pixel pitch of 0.2745 mm, this monitor offers clear and sharp images, making it suitable for various applications from gaming to productivity. Featuring an anti-glare coating and flicker-free technology, it minimizes eye strain during extended use while Dell ComfortView Plus further enhances the viewing experience by reducing harmful blue light emissions. The monitor boasts a wide horizontal and vertical viewing angle of 178 degrees, ensuring that colors remain consistent from different perspectives. A tilt adjustment range of -5 to +21 degrees provides flexibility for comfortable viewing angles. With HDMI and VGA input options, connectivity is straightforward. Additionally, the energy-efficient design is ENERGY STAR certified, affirming its commitment to environmentally sustainable performance while providing a vibrant display with 16.7 million colors available to enhance multimedia content.
  • Vivid display quality
    With a native resolution of 1920 x 1080, the Dell SE2425HM provides exceptional image clarity, making it suitable for entertainment, work, and creative tasks.
  • Eye comfort technology
    Features like Dell ComfortView Plus and flicker-free technology help reduce eye strain during long hours of use, ensuring a comfortable viewing experience.
  • Versatile connectivity
    Equipped with HDMI and VGA connections, this monitor allows for easy integration with a variety of devices, making it an excellent choice for any setup.
  • Adjustable viewing angles
    The tilt functionality provides the ability to customize the monitor’s angle for enhanced comfort and improved ergonomics.
  • Environmentally friendly
    Designed with sustainability in mind, this monitor is ENERGY STAR certified and incorporates materials aimed at reducing its environmental impact.
Dell SE2425HM - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/2192908
Energy Class
Class D
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (VGA: 60 Hz, HDMI: 100 Hz)
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC (CIE 1931)
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
53.864 cm x 17.881 cm x 41.226 cm
3.47 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
141 kg carbon emissions
Plug and Play, RoHS, NFPA 99, HDCP 1.4, BFR-reduced, PVC-reduced, TUV Rheinland Eye Comfort Certification (3-star)
Bundled Services
3 years Basic Hardware Service with Advanced Exchange
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% NTSC (CIE 1931)
Response Time
Vertical Refresh Rate
50 - 100 Hz
Horizontal Refresh Rate
30 - 110 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Eye comfort mode, 3-sided bezeless, Dell ComfortView Plus
53.864 cm x 17.881 cm x 41.226 cm - with stand
3.47 kg
HDMI (HDCP 1.4) , VGA
Mechanical
Tilt
Tilt Angle
-5/+21
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, cable management system
1 x HDMI cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
13 kWh/1000h
Power Consumption (Typical)
12.11 watt
Power Consumption (Max)
28.5 watt
Power Consumption Stand by
0.3 watt
Power Consumption (Off Mode)
0.3 watt
Dimensions & Weight Details
With stand - width: 53.864 cm - depth: 17.881 cm - height: 41.226 cm - weight: 3.47 kg , Without stand - width: 53.864 cm - depth: 4.77 cm - height: 32.421 cm - weight: 2.8 kg
Shipping Weight
5.01 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
ENERGY STAR Version
8.0
Carbon Footprint
Manufacturing (kg CO2e)
66.27
Logistics (kg CO2e)
9.45
Use (kg CO2e)
63.17
EOL (kg CO2e)
1.97
Total Carbon w/o Use Phase (kg CO2e)
77.832
PAIA Version
GaBi version 1, 2024
Bundled Services
10 - 80% (non-condensing)
