Dell SE2225HM 2" 1920x1080 5ms VGA HDMI LED Monitor
Quicklinx: J8NJWS00 Mfr#: DELL-SE2225HM
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: HDMI, VGA (HD-15)
More than 50 In Stock
£57.96 ex VAT
£69.55 inc VAT
The Dell SE2225HM monitor offers a 22-inch diagonal display with a native resolution of 1920 x 1080, providing clear and vibrant visuals with a pixel density of 102 PPI. This desktop monitor features VA TFT technology with a high image brightness of 250 cd/m2 and a contrast ratio of 3000:1, ensuring a rich viewing experience. With an anti-glare coating and Dell ComfortView Plus technology, it promotes eye comfort during long viewing sessions. The 178-degree horizontal and vertical viewing angles make it suitable for shared viewing environments.
Dell SE2225HM - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/2187041
Energy Class
Class D
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (VGA: 60 Hz, HDMI: 100 Hz)
Pixel Pitch
0.2493 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC (CIE 1931)
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
49.286 cm x 21.18 cm x 39.575 cm
2.96 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
97.6 kg carbon emissions
Plug and Play, RoHS, NFPA 99, HDCP 1.4, BFR-reduced, PVC-reduced, TUV Rheinland Eye Comfort Certification (3-star)
Bundled Services
3 years Basic Hardware Service with Advanced Exchange
Display Type
Energy Class
Class D
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2493 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Colour Gamut
72% NTSC (CIE 1931)
Response Time
Vertical Refresh Rate
50 - 100 Hz
Horizontal Refresh Rate
30 - 111 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Eye comfort mode, 3-sided bezeless, Dell ComfortView Plus
49.286 cm x 21.18 cm x 39.575 cm - with stand
2.96 kg
HDMI (HDCP 1.4) , VGA
Mechanical
Tilt
Tilt Angle
-5/+21
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, cable management system
1 x HDMI cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
12 kWh/1000h
Power Consumption (Typical)
12.1 watt
Power Consumption (Max)
20.7 watt
Power Consumption Stand by
0.3 watt
Power Consumption (Off Mode)
0.3 watt
Dimensions & Weight Details
With stand - width: 49.286 cm - depth: 21.18 cm - height: 39.575 cm - weight: 2.96 kg , Without stand - width: 49.286 cm - depth: 4.49 cm - height: 28.648 cm - weight: 2.23 kg
Shipping Weight
4.38 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
ENERGY STAR Version
8.0
Carbon Footprint
Manufacturing (kg CO2e)
57.78
Logistics (kg CO2e)
8.2
Use (kg CO2e)
30.06
EOL (kg CO2e)
1.46
Total Carbon w/o Use Phase (kg CO2e)
67.5392
PAIA Version
GaBi version 1, 2024
Bundled Services
10 - 80% (non-condensing)
Diagonal Size: 22in
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Dell
