With the expanded viewing area provided by an improved bezel, the Dell 22 Monitor offers an affordable, sleek design for everyday computing.
Stylish design
Enjoy the elegance of thin, glossy bezels, a sturdy base, and easy to use buttons. -
Video quality
Optimize your entertainment experience with rich and vibrant colors across wide viewing angles in Full HD resolution screen.
- Dell SE2216H - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Class
- Class E
- Energy Consumption per Year
- 26 kWh
- Power Consumption (On mode)
- 15.5 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.24795 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 8000000:1 (dynamic)
- Response Time
- 12 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 84% (CIE 1976)
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 50.62 cm x 17.99 cm x 39.57 cm
- Microsoft Certification
- Compatible with Windows 7
- Plug and Play, DDC/CI, RoHS, CECP, EDID compatible
- 3-year warranty
- Bundled Services
- 3 years Advanced Exchange Service
- Display Type
- Energy Class
- Class E
- 26 kWh
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.24795 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 148.5 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, clock, hue, aspect control
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- Integrated cable management, Flicker Free technology, BFR/PVC-free, Energy Gauge
- Black
- 50.62 cm x 17.99 cm x 39.57 cm - with stand
- HDMI , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- Security lock slot (cable lock sold separately), integrated cable management
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 15.5 W
- Power Consumption SDR (On mode)
- 15.5 kWh/1000h
- Power Consumption (Typical)
- 24 Watt
- Power Consumption (Max)
- 25 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.2 Watt
- Dimensions & Weight Details
- With stand - width: 50.62 cm - depth: 17.99 cm - height: 39.57 cm , Without stand - width: 50.62 cm - depth: 5.47 cm - height: 30.27 cm - weight: 2.78 kg
- Limited warranty - 3 years
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
