Dell SB521A Magnetic Sound bar
Quicklinx: GM0PWS00 Mfr#: DELL-SB521A
System Type: Sound bar - for monitor
Type: Sound bar
Power: 3.5Watt
34 In Stock
£36.88 ex VAT
£44.25 inc VAT
Slim and light soundbar offers exceptional audio clarity and easy magnetic attachment to your Dell monitors, ensuring a clutter-free desk.
  • The promise of superior audio clarity
    With slim and light soundbar, you get to enjoy rich and crystal-clear audio with powerful 3.6 W RMS speakers offering a wide frequency response range of 180 Hz to 20 kHz. Stay productive and never miss a call or an alert again.
  • A neat audio solution for your monitor
    The soundbar magnetically snaps on to your Dell monitori, allowing you to tilt, swivel and pivot your monitor in any direction, without getting in the way. The soundbar's USB cable plugs neatly to the USB-A port at the back of the monitor, so it's hidden from view.
  • Easy to setup and secure
    The Dell Slim Soundbar offers easy installation requiring no software, power cord, and batteries. Simply plug in the soundbar cable to your monitor's USB-A port.
Dell SB521A - sound bar - for monitor
Speaker Type
Active
Continuous Power
3.6 Watt
Frequency Response
180 - 20000 Hz
Amplifier
Integrated
29.8 cm x 1.8 cm x 2.4 cm
114 g
3-year warranty
Design Features
Built-in magnetic mount
Speaker System
Speaker Type
Active
Continuous Power
3.6 Watt
Frequency Response
180 - 20000 Hz
Amplifier
Integrated
Recommended Placing
Under-the-monitor
Connector Type
USB (4 PIN USB Type A)
Plug and Play
29.8 cm
1.8 cm
2.4 cm
114 g
Limited warranty - 3 years
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: GM0P 051052
Condition: item is a customer return , has been opened, but in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £24.15
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Sound bar
Power: 3.5Watt
Brand: Dell
Stock Status: Used Stock
