Slim and light soundbar offers exceptional audio clarity and easy magnetic attachment to your Dell monitors, ensuring a clutter-free desk.
The promise of superior audio clarity
With slim and light soundbar, you get to enjoy rich and crystal-clear audio with powerful 3.6 W RMS speakers offering a wide frequency response range of 180 Hz to 20 kHz. Stay productive and never miss a call or an alert again. -
A neat audio solution for your monitor
The soundbar magnetically snaps on to your Dell monitori, allowing you to tilt, swivel and pivot your monitor in any direction, without getting in the way. The soundbar's USB cable plugs neatly to the USB-A port at the back of the monitor, so it's hidden from view. -
Easy to setup and secure
The Dell Slim Soundbar offers easy installation requiring no software, power cord, and batteries. Simply plug in the soundbar cable to your monitor's USB-A port.
- Dell SB521A - sound bar - for monitor
- Product Type
- Sound bar - for monitor
- Speaker Type
- Active
- Continuous Power
- 3.6 Watt
- Frequency Response
- 180 - 20000 Hz
- Amplifier
- Integrated
- 29.8 cm x 1.8 cm x 2.4 cm
- 114 g
- 3-year warranty
- Product Type
- Design Features
- Built-in magnetic mount
Speaker System
- Speaker Type
- Active
- Continuous Power
- 3.6 Watt
- 180 - 20000 Hz
- Amplifier
- Integrated
- Recommended Placing
- Under-the-monitor
- Connector Type
- USB (4 PIN USB Type A)
- Plug and Play
- 29.8 cm
- 1.8 cm
- 2.4 cm
- 114 g
- Limited warranty - 3 years
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
GM0P 051052 Condition: item is a customer return , has been opened, but in excellent condition |
£27.91 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
