Empower your teams to collaborate efficiently on a color smart multifunction printer with low cost-per-page printing.
Simplify collaboration
Handle large-volume scans easily and with less waiting time using the single-pass, dual head duplex automatic document feeder. Print from and scan from the printer for improved collaboration. When paper is detected in the ADF or scan bed, the recent screen is automatically displayed with up 8 previous ADF or scan related tasks, saving you time and effort. -
Efficient performance
Print in vibrant color and fax, scan and copy on one device. Get fast print speeds and a high duty cycle. Enjoy low cost-per-page printing and save paper with automatic two-sided printing. This printer also supports printing on recycled, renewable content and chlorine-free paper. Just tap the icons on the on-screen dock menu or swipe the 4.3" touchscreen for easy activation. Launch recent tasks, including associated settings, with one touch of the recent icon. Printing large, complex files is hassle-free with a built-in memory. And enjoy convenient features such as Private/Public Mail Box Print and Proof Print. -
Easy maintenance
Reduce energy consumption and toner cartridge size with improved low-melt toner technology. Amazing toner cartridge design prevents spillage during shipping, eliminating the need for sealing tape, so replacement is quick and hassle-free upon delivery. Paper jams are easy to access and address without tearing so you can get back to work quickly. -
Essential security
Keep sensitive documents private with the Secure Print feature so print jobs are only released with a 4-digit PIN. Guard against unauthorized access with secure, walk-up user authentication and Lightweight Directory Access Protocol (LDAP).
- Dell S2825cdn - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 50000 pages
- Recommended Monthly Volume
- 700 - 3500 pages
- Max Copying Speed
- Up to 30 ppm (mono) / up to 30 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 600 x 600 dpi
- Display
- 4.3"
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, recycled paper, coated paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 850 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to application, scan to network, scan to FTP, scan to SMB, security lock slot
- 42.9 cm x 50.35 cm x 50 cm
- 31.7 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Fax Type
- Plain paper
- Laser - colour
- 50000 pages
- 700 - 3500 pages
- Display Diagonal Size
- 4.3"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy
Printing
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PCL 5c, PDF 1.7, XPS, URF, PWG
- First Print Out Time B/W
- 12 sec
- First Print Out Time Colour
- 12.5 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
Fax Machine Features
- Speed Dialing
- 200 station(s)
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), JIS B6 (128 x 182 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 300 sheets
- 850 sheets
- 50 sheets
- 150 sheets
- Bypass tray - 50 sheets , Input tray - 250 sheets , ADF - 50 sheets size: 139.7 x 139.7 mm - Legal (216 x 356 mm) , Output tray - 150 sheets
- Speed Details
- Printing: up to 30 ppm (Letter A) - B/W , Printing: up to 30 ppm (Letter A) - colour , Printing: up to 19 ppm (Letter A) - B/W duplex , Printing: up to 19 ppm (Letter A) - colour duplex , Copying: up to 30 ppm (Letter A) - B/W , Copying: up to 30 ppm (Letter A) - colour , Copying: up to 19 ppm (Letter A) - B/W duplex , Copying: up to 19 ppm (Letter A) - colour duplex , Scanning: up to 32 ppm (Letter A) - B/W , Scanning: up to 15 ppm (Letter A) - colour
- 1 x USB 2.0 - 4 pin USB Type B ¦ 1 x Gigabit LAN - RJ-45 ¦ 1 x USB 2.0 host - 4 pin USB Type A
- TLS, IPsec, 802.1x, PEAPv0
- Operating System Support
- MS Windows Server 2008 R2, Ubuntu Linux 12.04, MS Windows Server 2012 R2, MS Windows Server 2003 (32/64-bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.7 - 10.10
- Included Accessories
- Phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 1200 pages , 1 x toner cartridge (cyan) - up to 1200 pages , 1 x toner cartridge (magenta) - up to 1200 pages , 1 x toner cartridge (yellow) - up to 1200 pages
- GS, ICES-003, NOM, SABS, EN 61000-3-3, EN55024, WHQL, EN55022 Class B, FCC Part 15 B, FCC Part 68, FCC Part 15 C, RoHS, FCC Part 2, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, FDA, Energy-Related Products (ErP) Lot 6, REACH, CAN/CSA C22.2 No. 60950-1-07, RCM, Energy-Related Products (ErP) Lot 4, DHHS 21CFR (J), EN 61000-3-2 Class A, ICASA
- Security Slot Type
- Kensington security slot
- ENERGY STAR Certified
- Blue Angel Compliant
- 42.9 cm
- 50.35 cm
- 50 cm
- 31.7 kg
- Shipping Width
- 58 cm
- Shipping Depth
- 63.4 cm
- Shipping Height
- 65.9 cm
- Shipping Weight
- 36 kg
- 5 °C
- 32 °C
- 15 - 85% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
