Dell S2722QC 27" 3840x2160 4ms HDMI USB-C IPS LED Monitor
Quicklinx: H62GWS00 Mfr#: DELL-S2722QC
Diagonal Size: 27in
Max Resolution: 3840 x 2160
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: USB-C, HDMI
£302.21 ex VAT
£362.65 inc VAT
Enjoy unrivaled clarity on a 27" 4K UHD monitor with USB-C connectivity - one cable lets you transfer video, audio and data, along with power delivery.
  • A stunning setup
    Bring modern elegance to any space with the stunning Platinum Silver finish and a subtle textured back that gives your monitor a unique look. Plus, high functionality meets superb style with a three-sided ultrathin bezel design that allows you to see more with less distraction on this 27" screen.
  • A superior screen
    Experience 4 times more screen detail than FHD with the unrivaled clarity and vibrant color of UHD (3840 x 2160) resolution with HDR support. And In-Plane Switching (IPS) technology together with 99% sRGB color coverage lets you see extraordinary colors across a wide viewing angle.
  • Comfort comes first
    Customize your views with a height-adjustable stand and a monitor that tilts, swivels and pivots so you look your best and feel your best during work sessions or movie binges.
  • Versatile connectivity
    Easily charge and connect your laptop with USB-C connectivity and 65W of power delivery. This single-cable solution reduces cable clutter for a clutter-free desktop and transmits power, video, audio and data - all at once.
  • Perfect ports
    Charging and connecting your storage devices, mobile phones and other peripherals just got easier with a conveniently placed, quick-access USB 3.2 Gen 1 Type-A port.
  • Engaging audio
    Turn your monitor into an entertainment center with dual 3W integrated speakers.
  • Seamless switching
    Built-in dual HDMI ports keep your devices always plugged in and let you effortlessly switch between streaming and console gaming.
  • More ways to multitask
    Stay organized between applications, emails and windows on one screen using Dell Easy Arrange. You can also view multiple types of content from two different PC sources at once with Picture-by-Picture (PBP) or opt for Picture-in-Picture (PIP), which enables you to watch two images at once.
  • Leisure gaming
    Smooth, tear-free experience with AMD FreeSync technology, featuring up to 60Hz refresh rate.
  • Easy on the eyes
    This TÜV-certified monitor has a flicker-free screen with ComfortView, a feature that reduces harmful blue light emissions. It's designed to help reduce eye fatigue even over extended viewing - like your next movie marathon.
  • Energy conservation
    Save energy when your monitor is not in use with PowerNap, a feature that dims or puts your monitor to sleep when it's not in use.
Dell S2722QC - LED monitor - 4K - 27" - HDR
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/704920
Energy Class
Class F
Adaptive-Sync Technology
AMD FreeSync
USB 3.2 Gen 1/USB-C hub, USB PD 65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.1554 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (grey-to-grey extreme), 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
1.07 billion colours
Colour Gamut
99% sRGB
Input Connectors
2xHDMI, USB-C
Display Position Adjustments
Screen Coating
Anti-glare 3H hardness
Voltage
AC 100-240 V (50/60 Hz)
Platinum silver
Dimensions (WxDxH) - with stand (lowest position)
61.16 cm x 17.47 cm x 40.01 cm
7.1 kg
Carbon Footprint
638 kg carbon emissions
TUV, RoHS, BFR-free, DisplayPort 1.4, PVC-free
Bundled Services
3 years Advanced Exchange Basic Warranty
Display Type
Energy Class
Class F
Diagonal Size
27"
AMD FreeSync
Built-in Devices
USB Power Delivery
65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1554 mm
Pixel Per Inch
163
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
24 - 76 Hz
Horizontal Refresh Rate
10 - 137 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED edgelight backlight
Picture by picture, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Dell ComfortView, Picture-in-Picture, 3-sided bezeless
Platinum silver
61.16 cm x 17.47 cm x 40.01 cm - with stand (lowest position)
7.1 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
2 x HDMI , USB-C 3.2 Gen 1 upstream/DisplayPort 1.4 Alt Mode (power up to 65W) , USB 3.2 Gen 1 downstream , USB 3.2 Gen 1 downstream with Battery Charging 1.2 , Audio line-out
Mechanical
Tilt Angle
-5/+21
Swivel Angle
60
Rotation Angle
180
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
1 x USB-C 3.2 Gen 2 cable - 1 m
Security Slot Type
Kensington security slot
Input Voltage
24.8 kWh/1000h
Power Consumption (Max)
155 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.2 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (lowest position) - width: 61.16 cm - depth: 17.472 cm - height: 40.005 cm - weight: 7.1 kg , Without stand - width: 61.16 cm - depth: 5.543 cm - height: 36.464 cm - weight: 5.37 kg
Shipping Weight
9.79 kg
Sustainability Information
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
167
Manufacturing (kg CO2e)
369.19
Logistics (kg CO2e)
47.99
Use (kg CO2e)
215.47
EOL (kg CO2e)
5.54
Total Carbon w/o Use Phase (kg CO2e)
422.53
PAIA Version
1.3.2, 2022
Bundled Services
10 - 80% (non-condensing)
Accessories (1)
H62G Dell Dual Monitor Stand - MDS19 In Stock £166.38
Other bundles (6)
H62G Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £147.00
H62G Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £34.45
H62G Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £157.58
H62G Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £59.12
H62G Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US In Stock £33.64
H62G Dell Dell Speakerphone SP3022 In Stock £59.88
Diagonal Size: 27in
Response Time: 4ms
Interfaces: USB-C
Interfaces: HDMI
Brand: Dell
