An easy-to-use QHD monitor is made to fit your busy lifestyle with a built-in camera, noise-canceling microphones and dual 5W speakers.
Outstanding value
Connecting virtually with friends and co-workers gets a major upgrade with this monitor's built-in camera, noise-canceling microphones and dual 5W speakers. You'll enjoy amazing video clarity and crystal-clear sound. -
The power of USB-C
Versatile USB-C connectivity delivers video, audio and data, and charges your laptop with up to 65 watts of power (even when the monitor is off) with the Always On Power Delivery feature. Plus, with just one cord, you'll have a clutter-free desk space. -
Privacy when you want it
A super clear 5MP IR pop-up camera features facial recognition for convenient, instant sign-on. The camera stays hidden until you're ready for video chatting or selfies. -
Comfort comes first
A height-adjustable stand and a monitor that tilts, swivels and pivots let you look and feel perfectly for all-day conferencing. -
Engaging audio
Turn your monitor into the perfect entertainment center, with the help of 2 x 5W integrated speakers. -
A stunning setup
It brings a blend of great style and quality into every living space with a modern, sleek design and the ability to save desktop space by hooking to the wall with a VESA mount. -
Perfect ports
Charging and connecting your storage devices, mobile phones and other peripherals just got easier with a conveniently placed, quick-access USB 3.2 Gen 1 Type-A port. -
Keep everything in order
Stay organized between applications, emails and windows on one screen using Dell Easy Arrange. -
A stunning view
The three-sided ultrathin bezel design allows you to see more with less distraction for a better way to virtually meet your family, team, classmates, or even work-out coach and buddies. -
Brilliant from every angle
In-Plane Switching (IPS) technology together with 99% sRGB color coverage lets you see extraordinary colors across a wide viewing angle on the QHD (2560x1440) anti-glare screen. -
Leisure gaming
Get smooth, tear-free experience with AMD FreeSync technology, featuring up to 75Hz refresh rate. -
Next-level eye comfort
ComfortView Plus is an always-on, built-in low blue light screen that optimizes eye comfort by reducing potentially harmful blue light emissions while delivering excellent color accuracy.
- Dell S2722DZ - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/755450
- Energy Class
- Class F
- Power Consumption (On mode)
- 18.26 W
- Adaptive-Sync Technology
- AMD FreeSync
- IR camera, USB 3.2 Gen 1/USB-C hub, USB PD 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 75 Hz
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 4 ms (grey-to-grey extreme)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Audio Input
- Two microphones
- Built-in Webcam
- 5 Megapixel - 1920 x 1080 at 30 fps
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare 3H hardness
- Voltage
- AC 100-240 V (50/60 Hz)
- Dimensions (WxDxH) - with stand (lowest position)
- 61.16 cm x 17.47 cm x 40 cm
- Environmental Standards
- ENERGY STAR Qualified
- Carbon Footprint
- 622 kg carbon emissions
- RoHS, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free
- Bundled Services
- 3 years Advanced Exchange Basic Warranty
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 27"
- AMD FreeSync
- Built-in Devices
- USB Power Delivery
- 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2331 mm
- Pixel Per Inch
- 108.79
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 48 - 75 Hz
- Horizontal Refresh Rate
- 30 - 120 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED edgelight backlight
- LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Low Blue Light technology, 3-sided bezeless, Dell ComfortView Plus
- 61.16 cm x 17.47 cm x 40 cm - with stand (lowest position)
Built-in Webcam
- Sensor Resolution
- 5 Megapixel
- Max Video Resolution
- Fixed focus
Audio Input
- Two microphones
- Microphone Features
- Noise-cancelling
Audio
- Speakers - stereo
- Output Power / Channel
- 5 Watt
- HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , USB-C 3.2 Gen 1 upstream/DisplayPort 1.2 Alt Mode with Power Delivery (power up to 65W) , USB 3.2 Gen 1 downstream with Battery Charging 1.2 , USB 3.2 Gen 1 downstream , Audio line-out
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 60
- Rotation Angle
- 180
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
- Cables Included
- 1 x USB-C 3.2 Gen 1 cable - 1.8 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- 18.26 W
- Power Consumption SDR (On mode)
- 24 kWh/1000h
- Power Consumption (Max)
- 149 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.2 Watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand (lowest position) - width: 61.16 cm - depth: 17.47 cm - height: 40 cm - weight: 6.86 kg , With stand (highest position) - width: 61.16 cm - depth: 17.47 cm - height: 51 cm - weight: 6.86 kg , Without stand - width: 61.16 cm - depth: 5.674 cm - height: 36.584 cm - weight: 5.18 kg
- Shipping Weight
- 9.46 kg
Sustainability Information
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 148
- Manufacturing (kg CO2e)
- 397.6
- Logistics (kg CO2e)
- 45.68
- Use (kg CO2e)
- 173.23
- EOL (kg CO2e)
- 5.38
- Total Carbon w/o Use Phase (kg CO2e)
- 448.77
- PAIA Version
- 1.3.2, 2022
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Accessories (1)
Dell Dual Monitor Stand - MDS19 | In Stock | £166.38 |
Other bundles (6)
Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE | In Stock | £164.96 |
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £34.45 |
Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE | In Stock | £133.92 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £56.48 |
Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US | In Stock | £33.64 |
Dell Dell Speakerphone SP3022 | In Stock | £59.88 |
