Dell S2722DZ 27" 2560x1440 4ms HDMI DP IPS LED Monitor
Quicklinx: H0ZPWS00 Mfr#: DELL-S2722DZ
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, USB-C, HDMI
£153.27 ex VAT
£183.92 inc VAT
An easy-to-use QHD monitor is made to fit your busy lifestyle with a built-in camera, noise-canceling microphones and dual 5W speakers.
  • Outstanding value
    Connecting virtually with friends and co-workers gets a major upgrade with this monitor's built-in camera, noise-canceling microphones and dual 5W speakers. You'll enjoy amazing video clarity and crystal-clear sound.
  • The power of USB-C
    Versatile USB-C connectivity delivers video, audio and data, and charges your laptop with up to 65 watts of power (even when the monitor is off) with the Always On Power Delivery feature. Plus, with just one cord, you'll have a clutter-free desk space.
  • Privacy when you want it
    A super clear 5MP IR pop-up camera features facial recognition for convenient, instant sign-on. The camera stays hidden until you're ready for video chatting or selfies.
  • Comfort comes first
    A height-adjustable stand and a monitor that tilts, swivels and pivots let you look and feel perfectly for all-day conferencing.
  • Engaging audio
    Turn your monitor into the perfect entertainment center, with the help of 2 x 5W integrated speakers.
  • A stunning setup
    It brings a blend of great style and quality into every living space with a modern, sleek design and the ability to save desktop space by hooking to the wall with a VESA mount.
  • Perfect ports
    Charging and connecting your storage devices, mobile phones and other peripherals just got easier with a conveniently placed, quick-access USB 3.2 Gen 1 Type-A port.
  • Keep everything in order
    Stay organized between applications, emails and windows on one screen using Dell Easy Arrange.
  • A stunning view
    The three-sided ultrathin bezel design allows you to see more with less distraction for a better way to virtually meet your family, team, classmates, or even work-out coach and buddies.
  • Brilliant from every angle
    In-Plane Switching (IPS) technology together with 99% sRGB color coverage lets you see extraordinary colors across a wide viewing angle on the QHD (2560x1440) anti-glare screen.
  • Leisure gaming
    Get smooth, tear-free experience with AMD FreeSync technology, featuring up to 75Hz refresh rate.
  • Next-level eye comfort
    ComfortView Plus is an always-on, built-in low blue light screen that optimizes eye comfort by reducing potentially harmful blue light emissions while delivering excellent color accuracy.
Dell S2722DZ - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/755450
Energy Class
Class F
Power Consumption (On mode)
18.26 W
Adaptive-Sync Technology
AMD FreeSync
IR camera, USB 3.2 Gen 1/USB-C hub, USB PD 65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 75 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (grey-to-grey extreme)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort, USB-C
Audio Input
Two microphones
Built-in Webcam
5 Megapixel - 1920 x 1080 at 30 fps
Display Position Adjustments
Screen Coating
Anti-glare 3H hardness
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
61.16 cm x 17.47 cm x 40 cm
Environmental Standards
ENERGY STAR Qualified
Carbon Footprint
622 kg carbon emissions
RoHS, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free
Bundled Services
3 years Advanced Exchange Basic Warranty
Display Type
Energy Class
Class F
Diagonal Size
27"
AMD FreeSync
Built-in Devices
USB Power Delivery
65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
108.79
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 120 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED edgelight backlight
LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Low Blue Light technology, 3-sided bezeless, Dell ComfortView Plus
61.16 cm x 17.47 cm x 40 cm - with stand (lowest position)
Built-in Webcam
Sensor Resolution
5 Megapixel
Max Video Resolution
Fixed focus
Audio Input
Two microphones
Microphone Features
Noise-cancelling
Audio
Speakers - stereo
Output Power / Channel
5 Watt
HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , USB-C 3.2 Gen 1 upstream/DisplayPort 1.2 Alt Mode with Power Delivery (power up to 65W) , USB 3.2 Gen 1 downstream with Battery Charging 1.2 , USB 3.2 Gen 1 downstream , Audio line-out
Mechanical
Tilt Angle
-5/+21
Swivel Angle
60
Rotation Angle
180
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
1 x USB-C 3.2 Gen 1 cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
18.26 W
24 kWh/1000h
Power Consumption (Max)
149 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.2 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (lowest position) - width: 61.16 cm - depth: 17.47 cm - height: 40 cm - weight: 6.86 kg , With stand (highest position) - width: 61.16 cm - depth: 17.47 cm - height: 51 cm - weight: 6.86 kg , Without stand - width: 61.16 cm - depth: 5.674 cm - height: 36.584 cm - weight: 5.18 kg
Shipping Weight
9.46 kg
Sustainability Information
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
148
Manufacturing (kg CO2e)
397.6
Logistics (kg CO2e)
45.68
Use (kg CO2e)
173.23
EOL (kg CO2e)
5.38
Total Carbon w/o Use Phase (kg CO2e)
448.77
PAIA Version
1.3.2, 2022
Bundled Services
10 - 80% (non-condensing)
Accessories (1)
H0ZP Dell Dual Monitor Stand - MDS19 In Stock £174.65
Other bundles (5)
H0ZP Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £25.01
H0ZP Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £159.87
H0ZP Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £45.19
H0ZP Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US In Stock £33.64
H0ZP Dell Dell Speakerphone SP3022 In Stock £50.73
Diagonal Size: 27in
Response Time: 4ms
Interfaces: USB-C
Interfaces: HDMI
Brand: Dell
