Dell S2722DC 27" 2560x1440 4ms HDMI USB-C IPS LED Monitor
Quicklinx: J80BWS00 Mfr#: DELL-S2722DC
18 In Stock
£144.88 ex VAT
£173.85 inc VAT
The S2722DC is a 27" QHD monitor with outstanding visuals and USB-C connectivity. One cable lets you transfer video, audio and data along with power delivery.
  • A stunning setup
    Bring modern elegance to any space with the stunning Platinum Silver finish and a subtle textured back that gives your monitor a unique look. Plus, high functionality meets superb style with a three-sided ultrathin bezel design that allows you to see more with less distraction on this 27? screen.
  • A superior screen
    Experience 1.77 times more screen detail than FHD with the brilliant clarity and vibrant color of QHD (2560x1440) resolution. And In-Plane Switching (IPS) technology together with 99% sRGB color coverage lets you see extraordinary colors across a wide viewing angle.
  • Comfort comes first
    Customize your views with a height-adjustable stand and a monitor that tilts, swivels and pivots so you look your best and feel your best during work sessions or movie binges.
  • Versatile connectivity
    Easily charge and connect your laptop with USB-C connectivity and 65W of power delivery. This single-cable solution reduces cable clutter for a clutter-free desktop and transmits power, video, audio and data - all at once.
  • Perfect ports
    Charging and connecting your storage devices, mobile phones and other peripherals just got easier with a conveniently placed, quick-access USB 3.2 Gen 1 Type-A port.
  • Engaging audio
    Feel every beat pulse with built-in dual 3W integrated speakers.
  • Seamless switching
    Built-in dual HDMI ports keep your devices always plugged in and let you effortlessly switch between streaming and console gaming.
  • Keep everything in order
    Stay organized between applications, emails and windows on one screen using Dell Easy Arrange.
  • Leisure gaming
    Smooth, tear-free experience with AMD FreeSync technology, featuring up to 75Hz refresh rate.
  • Easy on the eyes
    This TÜV-certified monitor has a flicker-free screen with ComfortView, a feature that reduces harmful blue light emissions. It's designed to help reduce eye fatigue even over extended viewing - like your next movie marathon.
Dell S2722DC - LED monitor - QHD - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/699422
Energy Class
Class E
Power Consumption (On mode)
17.7 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.2 Gen 1/USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 75 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (grey-to-grey extreme), 5 ms (grey-to-grey fast), 8 ms (grey-to-grey typical)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
2xHDMI, USB-C
Display Position Adjustments
Screen Coating
Anti-glare, Haze 25%
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
61.16 cm x 17.472 cm x 40.005 cm
Carbon Footprint
587 kg carbon emissions
Plug and Play, RoHS, BFR-free, PVC-free
Bundled Services
3 years Advanced Exchange Service
Display Type
Energy Class
Class E
Diagonal Size
27"
AMD FreeSync
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 114 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED edgelight backlight
Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Dell ComfortView, 3-sided bezeless
61.16 cm x 17.472 cm x 40.005 cm - with stand (lowest position)
Audio
Speakers - stereo
Output Power / Channel
3 Watt
2 x HDMI , USB-C upstream/DisplayPort 1.2 Alt Mode with Power Delivery (power up to 65W) , USB 3.2 Gen 1 downstream with Battery Charging 1.2 , USB 3.2 Gen 1 downstream , Audio line-out
Mechanical
Tilt Angle
-5/+21
Swivel Angle
60
Rotation Angle
180
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
1 x USB-C 3.2 Gen 1 cable - 1.8 m
Input Voltage
17.7 W
17.7 kWh/1000h
Power Consumption (Max)
155 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.2 Watt
Dimensions & Weight Details
With stand (highest position) - width: 61.16 cm - depth: 17.472 cm - height: 51.005 cm , Without stand - width: 61.16 cm - depth: 5.543 cm - height: 36.464 cm - weight: 5.4 kg
Shipping Weight
9.78 kg
Sustainability Information
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
142
Manufacturing (kg CO2e)
366.25
Logistics (kg CO2e)
48.16
Use (kg CO2e)
166.88
EOL (kg CO2e)
5.52
Total Carbon w/o Use Phase (kg CO2e)
420.12
PAIA Version
1.3.2, 2022
Bundled Services
10 - 80% (non-condensing)
Brand: Dell
