Experience sharp and undistorted moving images with NVIDIA G-SyncTM and the fastest refresh rate at 144 Hz for sharp, jitter-free graphics that drastically reduce motion blur.
Enjoy incredibly swift and responsive gameplay with minimum input lag at an extremely rapid 1ms panel response time.
Enjoy vivid edge-to-edge gameplay with the Dell 27 Monitor, equipped with crisp QHD resolution - that's 3.68 million pixels - giving you close to two times more details on screen than Full HD.
Crystal clear motion
Experience sharp and undistorted moving images with NVIDIA G-SyncTM and the fastest refresh rate at 144 Hz for sharp, jitter-free graphics that drastically reduce motion blur. -
Leave lag time behind
Enjoy incredibly swift and responsive gameplay with minimum input lag at an extremely rapid 1ms panel response time. -
Bask in every detail
Enjoy vivid edge-to-edge gameplay with the Dell 27 Monitor, equipped with crisp QHD resolution - that's 3.68 million pixels - giving you close to two times more details on screen than Full HD. -
Made to game your way
With tilt, pivot, swivel and height adjustable features, you can find your ideal viewing position and game for long hours comfortably. -
Effortless connectivity
Connect easily to secondary devices and peripherals like your headphones, mouse and keyboard with its wide range of ports, including an HDMI 1.4, DisplayPort 1.2, and 4 USB 3.0 downstream ports. -
Console play at your command
Hook up the Dell 27 Monitor to your PC via the DP1.2, and add another secondary device - like your gaming console of choice - via the HDMI for simultaneous entertainment options.
- Dell S2716DG - LED monitor - 27" - with 3-Years Advanced Exchange Warranty
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A+
- Energy Consumption per Year
- 34 kWh
- Adaptive-Sync Technology
- NVIDIA G-SYNC
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 144 Hz
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 1 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 72% NTSC, 82% (CIE 1976)
- Input Connectors
- HDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 61.25 cm x 20.03 cm x 41.63 cm
- Localisation
- United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Plug and Play
- 3-year warranty
- Bundled with
- 3-Years Advanced Exchange Warranty
- Display Type
- Energy Class
- Class A+
- 34 kWh
- Diagonal Size
- 27"
- NVIDIA G-SYNC
- Built-in Devices
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- 1 ms
- Vertical Refresh Rate
- 30 - 145 Hz
- Horizontal Refresh Rate
- 69.7 - 250.6 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, input select, colour temperature
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- LED edgelight system, Energy Gauge, backlight dimming control, arsenic-free glass, 72% NTSC colour gamut
- Black
- 61.25 cm x 20.03 cm x 41.63 cm - with stand
- Bundled with
- DisplayPort , HDMI , 4 x USB 3.0 downstream (Type A) , Audio line-out , Headphones , USB 3.0 upstream (Type B)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
- Included Accessories
- Stand
- Cables Included
- 1 x DisplayPort cable , 1 x SuperSpeed USB cable
- Plug and Play
- Localisation
- United Kingdom
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 90 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Included Software
- Drivers & Utilities
- Dimensions & Weight Details
- With stand - width: 61.25 cm - depth: 20.03 cm - height: 41.63 cm , Without stand - width: 61.25 cm - depth: 5.56 cm - height: 36.25 cm - weight: 4.4 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
