Dell S2716DG 27" 2560x1440 1ms HDMI DisplayPort USB LED Gaming Monitor
Quicklinx: BR9WWS00 Mfr#: 210-AGUL
Experience sharp and undistorted moving images with NVIDIA G-SyncTM and the fastest refresh rate at 144 Hz for sharp, jitter-free graphics that drastically reduce motion blur.
Enjoy incredibly swift and responsive gameplay with minimum input lag at an extremely rapid 1ms panel response time.
Enjoy vivid edge-to-edge gameplay with the Dell 27 Monitor, equipped with crisp QHD resolution - that's 3.68 million pixels - giving you close to two times more details on screen than Full HD.
  • Crystal clear motion
  • Leave lag time behind
  • Bask in every detail
  • Made to game your way
    With tilt, pivot, swivel and height adjustable features, you can find your ideal viewing position and game for long hours comfortably.
  • Effortless connectivity
    Connect easily to secondary devices and peripherals like your headphones, mouse and keyboard with its wide range of ports, including an HDMI 1.4, DisplayPort 1.2, and 4 USB 3.0 downstream ports.
  • Console play at your command
    Hook up the Dell 27 Monitor to your PC via the DP1.2, and add another secondary device - like your gaming console of choice - via the HDMI for simultaneous entertainment options.
Dell S2716DG - LED monitor - 27" - with 3-Years Advanced Exchange Warranty
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
34 kWh
Adaptive-Sync Technology
NVIDIA G-SYNC
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 144 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
1 ms
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 72% NTSC, 82% (CIE 1976)
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
61.25 cm x 20.03 cm x 41.63 cm
United Kingdom
Microsoft Certification
Compatible with Windows 7
Carbon Footprint
684 kg carbon emissions
Plug and Play
3-year warranty
Bundled with
Display Type
Energy Class
Class A+
34 kWh
Diagonal Size
27"
NVIDIA G-SYNC
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
1 ms
Vertical Refresh Rate
30 - 145 Hz
Horizontal Refresh Rate
69.7 - 250.6 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, input select, colour temperature
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
LED edgelight system, Energy Gauge, backlight dimming control, arsenic-free glass, 72% NTSC colour gamut
61.25 cm x 20.03 cm x 41.63 cm - with stand
Bundled with
DisplayPort , HDMI , 4 x USB 3.0 downstream (Type A) , Audio line-out , Headphones , USB 3.0 upstream (Type B)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
Stand
1 x DisplayPort cable , 1 x SuperSpeed USB cable
Plug and Play
United Kingdom
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
90 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 61.25 cm - depth: 20.03 cm - height: 41.63 cm , Without stand - width: 61.25 cm - depth: 5.56 cm - height: 36.25 cm - weight: 4.4 kg
Sustainability Information
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
119
Manufacturing (kg CO2e)
418
Logistics (kg CO2e)
66
Use (kg CO2e)
196
EOL (kg CO2e)
4
Total Carbon w/o Use Phase (kg CO2e)
488
PAIA Version
9/5/2018
Limited warranty - 3 years
10 - 80% (non-condensing)
BR9W C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
