Dell S2425HS 24" 1920x1080 4ms HDMI IPS LED Monitor
Quicklinx: JB77WS00 Mfr#: DELL-S2425HS
Discover the perfect blend of performance and comfort with the Dell S2425HS monitor. Designed for both professionals and home users, this 24-inch monitor combines a sleek, ergonomic design with advanced technology for a superior viewing experience. Enjoy stunning visuals with Full HD 1080p resolution, a 99% sRGB color gamut, and 16.8 million colors, all brought to life with LED backlight technology. The anti-glare screen with 3H Hard Coating ensures a comfortable viewing experience, even in bright lighting conditions.
The Dell S2425HS is built for convenience and flexibility, featuring dual HDMI ports for easy connectivity and an included HDMI cable to get you started immediately. Its ergonomic design allows for height, pivot, swivel, and tilt adjustments, ensuring you can find the perfect viewing angle for any task. Advanced features like Dell ComfortView Plus, Flicker-Free technology, and Low Blue Light technology reduce eye strain and make this monitor a comfortable choice for extended use.
Committed to sustainability, the Dell S2425HS is ENERGY STAR certified, mercury-free, and features arsenic-free glass, making it a responsible choice for environmentally conscious users.
Dell S2425HS - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1856261
Energy Class
Class D
Power Consumption (On mode)
14.5 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 100 Hz
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1500:1
Response Time
4 ms (extreme), 5 ms (fast), 8 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB (CIE 1931)
Input Connectors
2xHDMI
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
53.764 cm x 18.814 cm x 35.124 cm
4.86 kg
Pricing Type
BTO
Environmental Standards
ENERGY STAR Qualified
Carbon Footprint
166 kg carbon emissions
Plug and Play, RoHS, BFR-reduced, PVC-reduced
Bundled Services
3 years Basic Hardware Service with Advanced Exchange after remote diagnosis
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
1500:1
Colour Support
Colour Gamut
99% sRGB (CIE 1931)
Response Time
Vertical Refresh Rate
48 - 100 Hz
Horizontal Refresh Rate
30 - 110 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Flicker Free technology, Mercury free, OSD controller, arsenic-free glass, Dell Easy Arrange, Low Blue Light technology, 3-sided bezeless, Dell ComfortView Plus
53.764 cm x 18.814 cm x 35.124 cm - with stand (lowest position)
4.86 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
2 x HDMI
Mechanical
Tilt Angle
-5/+21
Swivel Angle
60
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
1 x HDMI cable - 1.8 m
Pricing Type
BTO
Security Slot Type
Kensington security slot
Input Voltage
14.5 W
14.5 kWh/1000h
Power Consumption (Typical)
13 Watt
Power Consumption (Max)
42 Watt
Power Consumption Stand by
0.4 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (lowest position) - width: 53.764 cm - depth: 18.814 cm - height: 35.124 cm - weight: 4.86 kg , With stand (highest position) - width: 53.764 cm - depth: 18.814 cm - height: 47.703 cm - weight: 4.86 kg , Without stand - width: 53.764 cm - depth: 5.889 cm - height: 31.373 cm - weight: 3.19 kg
Shipping Weight
6.87 kg
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
8.0
Carbon Footprint
Manufacturing (kg CO2e)
77.19
Logistics (kg CO2e)
12.95
Use (kg CO2e)
71.88
EOL (kg CO2e)
3.98
Total Carbon w/o Use Phase (kg CO2e)
94.12
PAIA Version
GaBi version 1
Bundled Services
10 - 80% (non-condensing)
