With the expanded viewing area provided by an improved bezel, the Dell 22 Monitor offers an affordable, sleek design for everyday computing.
Engaging video and audio experience
Maximize your entertainment experience with rich and vibrant colors across wide viewing angles in Full HD resolution, a sleek screen, and dual 3W integrated speakers. -
Stylish design
Enjoy the elegance of thin, glossy bezels, a sturdy base, and intuitive capacitive touch buttons. -
Reliable and easy to use
Built to comply with the environmental and regulatory standards, legacy and future-ready PCs with VGA and HDMI ports.
- Dell S2216H - LED monitor - Full HD (1080p) - 22" - with 3-Years Advance Exchange Service
- LED-backlit LCD monitor - 22"
- Energy Class
- Class A
- Energy Consumption per Year
- 29 kWh
- Power Consumption (On mode)
- 18.5 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 8000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 16.8 million colours
- Colour Gamut
- 72% (CIE 1931), 82% (CIE 1976)
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 48.8 cm x 17.99 cm x 38.57 cm
- 3.14 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play
- 3-year warranty
- Bundled with
- 3-Years Advance Exchange Service
- Display Type
- Energy Class
- Class A
- 29 kWh
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 148.5 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue, aspect control
- LED edgelight system
- Black
- 48.8 cm x 17.99 cm x 38.57 cm - with stand
- 3.14 kg
- Bundled with
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
- HDMI , VGA , Audio line-in , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- Included Accessories
- Stand
- Cables Included
- 1 x HDMI cable
- Plug and Play
- Security Slot Type
- Kensington security slot
- Input Voltage
- 18.5 W
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 48.8 cm - depth: 17.99 cm - height: 38.57 cm - weight: 3.14 kg , Without stand - width: 48.8 cm - depth: 5.42 cm - height: 29.31 cm - weight: 2.6 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
