Dell S2216H 21.5" 1920x1080 6ms VGA HDMI LED Monitor
Quicklinx: BPVLWS00 Mfr#: 210-AFYS
With the expanded viewing area provided by an improved bezel, the Dell 22 Monitor offers an affordable, sleek design for everyday computing.
  • Engaging video and audio experience
    Maximize your entertainment experience with rich and vibrant colors across wide viewing angles in Full HD resolution, a sleek screen, and dual 3W integrated speakers.
  • Stylish design
    Enjoy the elegance of thin, glossy bezels, a sturdy base, and intuitive capacitive touch buttons.
  • Reliable and easy to use
    Built to comply with the environmental and regulatory standards, legacy and future-ready PCs with VGA and HDMI ports.
Dell S2216H - LED monitor - Full HD (1080p) - 22" - with 3-Years Advance Exchange Service
LED-backlit LCD monitor - 22"
Energy Class
Class A
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
18.5 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.8 million colours
Colour Gamut
72% (CIE 1931), 82% (CIE 1976)
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
48.8 cm x 17.99 cm x 38.57 cm
3.14 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play
3-year warranty
Bundled with
Display Type
Energy Class
Class A
29 kWh
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue, aspect control
LED edgelight system
48.8 cm x 17.99 cm x 38.57 cm - with stand
3.14 kg
Bundled with
Audio
Speakers - stereo
Output Power / Channel
3 Watt
HDMI , VGA , Audio line-in , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+21
Stand
1 x HDMI cable
Plug and Play
Security Slot Type
Kensington security slot
Input Voltage
18.5 W
Power Consumption (Typical)
30 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 48.8 cm - depth: 17.99 cm - height: 38.57 cm - weight: 3.14 kg , Without stand - width: 48.8 cm - depth: 5.42 cm - height: 29.31 cm - weight: 2.6 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
BPVL C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
