Dell ProfessionalP2214H 22" 1920x1080 8ms VGA DVI DP IPSLED NoSt
Quicklinx: BVYYWS00 Mfr#: 210-AGYC
The Dell 22 monitor - P2214H adjusts to fit your work style and provides virtually all the connectivity options you'll need over the course of the day. The in-plane switching technology offers clear images with consistent and accurate colors across a wide 16:9 aspect ratio. The Dell 22 monitor - P2214H meets the latest regulatory and environmental standards.
Stand not included
  • Flexible viewing features
  • Color clarity and consistency across an ultra-wide viewing angle
  • Designed for professionals
    For large and small businesses, the P2214H is ideal for Latitude, OptiPlex and Dell Precision systems driving high-performance business applications. It is also an excellent display for Latitude and XPS systems in home-office environments.
  • Environment-conscious design
  • Energy-efficient design
    With 26 W normal-operation power consumption (typical) and less than 0.3 W power consumption in active-off mode, the P2214H can help keep energy costs down. Manage power consumption wisely with PowerNap, which you can enable through the Dell Display Manager to either dim the monitor to the minimum brightness level or put it into sleep mode when it is not in use.
  • Outstanding screen clarity for productive offices
    Bright, clear with the viewing features and connectivity options that help boost productivity in business and at home.
Dell P2214H - without stand - LED monitor - Full HD (1080p) - 22" - with 3-Years Advanced Exchange Warranty
LED-backlit LCD monitor - 22"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 85% (CIE 1976)
Input Connectors
DVI-D, VGA, DisplayPort
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
51.27 cm x 4.63 cm x 30.44 cm
3.26 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC/CI
3-year warranty
Bundled with
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
LED edgelight system, adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Energy Saver, Image Enhance, arsenic-free glass
51.27 cm x 4.63 cm x 30.44 cm - without stand
3.26 kg
Bundled with
DVI-D , DisplayPort , VGA , USB 2.0 upstream (Type B) , 4 x USB 2.0 downstream (Type A)
Mechanical
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support, Dell Soundbar mounting slots
Cable management cover
1 x DisplayPort cable , 1 x USB cable , 1 x VGA cable
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
42 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
BVYY C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.17
