The Dell 22 monitor - P2214H adjusts to fit your work style and provides virtually all the connectivity options you'll need over the course of the day. The in-plane switching technology offers clear images with consistent and accurate colors across a wide 16:9 aspect ratio. The Dell 22 monitor - P2214H meets the latest regulatory and environmental standards.
Flexible viewing features
The Dell 22 monitor - P2214H adjusts to fit your work style and provides virtually all the connectivity options you'll need over the course of the day. -
Color clarity and consistency across an ultra-wide viewing angle
The in-plane switching technology offers clear images with consistent and accurate colors across a wide 16:9 aspect ratio. -
Designed for professionals
For large and small businesses, the P2214H is ideal for Latitude, OptiPlex and Dell Precision systems driving high-performance business applications. It is also an excellent display for Latitude and XPS systems in home-office environments. -
Environment-conscious design
The Dell 22 monitor - P2214H meets the latest regulatory and environmental standards. -
Energy-efficient design
With 26 W normal-operation power consumption (typical) and less than 0.3 W power consumption in active-off mode, the P2214H can help keep energy costs down. Manage power consumption wisely with PowerNap, which you can enable through the Dell Display Manager to either dim the monitor to the minimum brightness level or put it into sleep mode when it is not in use. -
Outstanding screen clarity for productive offices
Bright, clear with the viewing features and connectivity options that help boost productivity in business and at home.
- Dell P2214H - LED monitor - Full HD (1080p) - 22" - with 3-Years Advanced Exchange Warranty
- LED-backlit LCD monitor - 22"
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 85% (CIE 1976)
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 51.27 cm x 18 cm x 35.42 cm
- 5.13 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, DDC/CI
- 3-year warranty
- Bundled with
- 3-Years Advanced Exchange Warranty
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 148.5 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue, aspect control
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- LED edgelight system, stand lock, adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Energy Saver, Image Enhance, arsenic-free glass
- Black
- 51.27 cm x 18 cm x 35.42 cm - with stand
- 5.13 kg
- Bundled with
- DVI-D , DisplayPort , VGA , USB 2.0 upstream (Type B) , 4 x USB 2.0 downstream (Type A)
Mechanical
- Tilt Angle
- -5.5/+22
- Swivel Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management, VESA interface support, Dell Soundbar mounting slots
- Included Accessories
- Stand, cable management cover
- Cables Included
- 1 x DisplayPort cable , 1 x USB cable , 1 x VGA cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 42 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 51.27 cm - depth: 18 cm - height: 35.42 cm - weight: 5.13 kg , Without stand - width: 51.27 cm - depth: 4.63 cm - height: 30.44 cm - weight: 3.26 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
C2G 2m DisplayPort Male to HD Male Adapter Cable - Black | In Stock | £25.26 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
