Bright, clear and comfortable to view monitor. Help boost productivity at work and enrich entertainment at home in beautiful HD with adjustable viewing features and enhanced connectivity possibilities.
Help boost productivity at work and enrich entertainment at home in beautiful HD with adjustable viewing features and enhanced connectivity. -
Flexible viewing features
The Dell 20 monitor - P2014H adjusts to comfortably fit the way you work and play. Tilt, pivot, swivel and adjust the height of your monitor to maximize viewing comfort. -
Excellent screen clarity
Every detail is bright and clear with the crispness of LED backlighting. -
Color clarity and consistency across an ultra-wide viewing angle
The in-plane switching technology offers clear images with consistent and accurate colors across a wide 16:9 aspect ratio. -
Energy-efficient design
With 20 W normal-operation power consumption (typical) and less than 0.3 W power consumption in active-off mode, the P2014H can help keep your energy costs down.
- Dell P2014H - LED monitor - 20" - with 3-Years Advance Exchange Service
- LED-backlit LCD monitor - 20"
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900 at 60 Hz
- Pixel Pitch
- 0.2712 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 83% (CIE 1976)
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 47.05 cm x 18 cm x 35.42 cm
- 4.35 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, DDC/CI, RoHS
- 3-year warranty
- Bundled with
- 3-Years Advance Exchange Service
- Display Type
- Diagonal Size
- 20"
- Viewable Size
- 19.5"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2712 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue, aspect control
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- Overdrive technology, LED edgelight system, stand lock, adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Image Enhance, arsenic-free glass
- Black
- 47.05 cm x 18 cm x 35.42 cm - with stand
- 4.35 kg
- Bundled with
- DVI-D , DisplayPort , VGA , 4 x USB 2.0 downstream (Type A) , USB 2.0 upstream (Type B)
Mechanical
- Tilt Angle
- -5.5/+22
- Swivel Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), Dell Energy Smart, integrated cable management, portrait / landscape mode, VESA interface support, Dell Soundbar mounting slots
- Included Accessories
- Stand, cable management cover
- Cables Included
- 1 x USB cable , 1 x VGA cable , 1 x DisplayPort cable
- Input Voltage
- Power Consumption (Typical)
- 36 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 47.05 cm - depth: 18 cm - height: 35.42 cm - weight: 4.35 kg , Without stand - width: 47.05 cm - depth: 4.65 cm - height: 27.29 cm - weight: 2.48 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
