Dell Professional P2014H 19.5" 1600x900 8ms VGA DVI DP IPS LED Mo
Quicklinx: BVYVWS00 Mfr#: 210-AGZU
Bright, clear and comfortable to view monitor. Help boost productivity at work and enrich entertainment at home in beautiful HD with adjustable viewing features and enhanced connectivity possibilities.
  • Bright, clear and comfortable to view
    Help boost productivity at work and enrich entertainment at home in beautiful HD with adjustable viewing features and enhanced connectivity.
  • Flexible viewing features
    The Dell 20 monitor - P2014H adjusts to comfortably fit the way you work and play. Tilt, pivot, swivel and adjust the height of your monitor to maximize viewing comfort.
  • Excellent screen clarity
    Every detail is bright and clear with the crispness of LED backlighting.
  • Color clarity and consistency across an ultra-wide viewing angle
    The in-plane switching technology offers clear images with consistent and accurate colors across a wide 16:9 aspect ratio.
  • Energy-efficient design
    With 20 W normal-operation power consumption (typical) and less than 0.3 W power consumption in active-off mode, the P2014H can help keep your energy costs down.
Dell P2014H - LED monitor - 20" - with 3-Years Advance Exchange Service
LED-backlit LCD monitor - 20"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.2712 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 83% (CIE 1976)
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
47.05 cm x 18 cm x 35.42 cm
4.35 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC/CI, RoHS
3-year warranty
Bundled with
Display Type
Diagonal Size
20"
Viewable Size
19.5"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.2712 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Overdrive technology, LED edgelight system, stand lock, adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Image Enhance, arsenic-free glass
47.05 cm x 18 cm x 35.42 cm - with stand
4.35 kg
Bundled with
DVI-D , DisplayPort , VGA , 4 x USB 2.0 downstream (Type A) , USB 2.0 upstream (Type B)
Mechanical
Tilt Angle
-5.5/+22
Swivel Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Dell Energy Smart, integrated cable management, portrait / landscape mode, VESA interface support, Dell Soundbar mounting slots
Stand, cable management cover
1 x USB cable , 1 x VGA cable , 1 x DisplayPort cable
Input Voltage
Power Consumption (Typical)
36 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 47.05 cm - depth: 18 cm - height: 35.42 cm - weight: 4.35 kg , Without stand - width: 47.05 cm - depth: 4.65 cm - height: 27.29 cm - weight: 2.48 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
BVYV C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.43
BVYV C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £14.85
