Experience great audio clarity with this wired headset that provides convenient call controls at your fingertips.
Adjustable headband
Allows for a comfortable and secure fit. -
Ear cushions
Provide comfort during extended wear. -
Boom microphone
Enables clear voice transmission during calls. -
Call button
Used for answering and ending calls. -
Volume up/down button
Adjusts the listening volume up or down. -
Mute button
Mutes the headset during calls. -
Call status indicator
LED indicators for call status and functions.
- Dell Pro Stereo Headset WH3022 - headset
- Product Type
- Headset - wired - USB
- Compatibility
- Mac, Windows
- Recommended Use
- Computer
- Connectivity Technology
- Wired
- Sound Output Mode
- Hi-Fi stereo
- Controls
- Status indicator
- Software Certification
- Certified for Microsoft Teams, Zoom Certified
- 3-year warranty
- Product Type
- Compatibility
- Mac, Windows
- 19 cm
- 6 cm
- 21 cm
- 96 g
- Earpad Material
- Foam
- Recommended Use
- Computer
Audio Output
- Wired
- Sound Output Mode
- Hi-Fi stereo
- Adjustable Headband
- SoundGuard Technology
Remote Control
- Controls
- Status indicator
- Cable Details
- USB cable
- G616
- Limited hardware warranty - advanced exchange programme - 3 years
