The Dell Pro Smart Dock SD25 is designed to streamline connectivity with an integrated USB-C cable that reaches 90 cm, allowing for tidy and efficient organization. This docking station supports a range of interfaces, including USB 3.2 Gen 2, HDMI, and DisplayPort 1.4, catering to various display setups with resolutions up to 6K. Furthermore, the Smart Dock features advanced networking capabilities, ensuring a reliable connection through 2.5G Gigabit Ethernet, perfect for high-speed data transfer and smooth performance. With functionalities like wake on LAN and remote IT management, users can expect seamless integration into their workspace. The dock also includes a power delivery system, providing 130W for Dell systems and 96W for non-Dell systems, ensuring devices stay charged while connected. Built-in security features such as the Noble Wedge security slot enhance safe usage, making the Dell Pro Smart Dock SD25 a choice for professionals looking for reliability and efficiency in their work environment.
- Dell Pro Smart Dock SD25 - docking station - USB-C - HDMI, 2 x DP, USB-C - 1GbE, 2.5GbE
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- 20.5 cm x 9 cm x 3.525 cm
- 562 g
- Networking
- Gigabit Ethernet, 2.5 Gigabit Ethernet
- Power
- Power adapter AC 100-240 V (50 - 60 Hz) 180 watt Power Provided (19.5 V)
- Pricing Type
- BTO
- Carbon Footprint
- 91.8 kg carbon emissions
- Bundled Services
- 3 years Basic Hardware Service with Advanced Exchange after remote diagnosis
- Product Type
- Docking station
- 20.5 cm
- 9 cm
- 3.525 cm
- 562 g
Video
- Max Resolution Details
- 4K - 60 Hz (Quad Display) , 5K - 60 Hz (Dual Display) , 6K - 60 Hz (Single Display)
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
- 2 x display / video - DisplayPort - 20 pin DisplayPort (1.4) , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB-C 3.2 Gen 2/DisplayPort 1.4 - 24 pin USB-C , 1 x USB-C 3.2 Gen 2 - 24 pin USB-C , 4 x USB 3.2 Gen 2 - 9 pin USB Type A , 1 x network - 2.5G Gigabit Ethernet - RJ-45
- Cables Included
- 1 x USB-C cable - integrated - 90 cm
- Security lock slot (cable lock sold separately), wake on LAN, Preboot Execution Environment (PXE) support, 3 LED indicators, MAC address pass-through, 130W power delivery to Dell systems, Dell Power Button Sync, Kernel Direct Memory Access (DMA) protection, Remote IT management, remote firmware updates without a PC, 96W power delivery to non-Dell systems
- Security Slot Type
- Noble Wedge security slot / Kensington security slot
- DisplayPort 1.4
- Pricing Type
- BTO
Sustainability
- Carbon Footprint
- Manufacturing (kg CO2e)
- 28.27
- Logistics (kg CO2e)
- 2.02
- Use (kg CO2e)
- 60.5
- EOL (kg CO2e)
- 1.1
- Total Carbon w/o Use Phase (kg CO2e)
- 31.3038
- PAIA Version
- GaBi version 1, 2025
- Power Device
- Power adapter
- Voltage Required
- AC 100-240 V (50 - 60 Hz)
- Power Provided
- 180 watt
- Voltage Provided
- 19.5 V
- OS Required
- Red Hat Enterprise Linux, Google Chrome OS, Windows 10, Windows 11, Ubuntu 24.04
- Bundled Services
- 0 °C
- 35 °C
