Dell Pro Smart Dock SD25 - docking station - USB-C - HDMI, 2 x DP, USB-C - 1GbE, 2.5GbE
Quicklinx: JDRLWS00 Mfr#: DELL-SD25
More than 50 In Stock
£212.13 ex VAT
£254.55 inc VAT
The Dell Pro Smart Dock SD25 is designed to streamline connectivity with an integrated USB-C cable that reaches 90 cm, allowing for tidy and efficient organization. This docking station supports a range of interfaces, including USB 3.2 Gen 2, HDMI, and DisplayPort 1.4, catering to various display setups with resolutions up to 6K. Furthermore, the Smart Dock features advanced networking capabilities, ensuring a reliable connection through 2.5G Gigabit Ethernet, perfect for high-speed data transfer and smooth performance. With functionalities like wake on LAN and remote IT management, users can expect seamless integration into their workspace. The dock also includes a power delivery system, providing 130W for Dell systems and 96W for non-Dell systems, ensuring devices stay charged while connected. Built-in security features such as the Noble Wedge security slot enhance safe usage, making the Dell Pro Smart Dock SD25 a choice for professionals looking for reliability and efficiency in their work environment.
Docking station
Docking Interface
USB-C
Video Interfaces
HDMI, 2 x DP, USB-C
20.5 cm x 9 cm x 3.525 cm
562 g
Gigabit Ethernet, 2.5 Gigabit Ethernet
Power adapter AC 100-240 V (50 - 60 Hz) 180 watt Power Provided (19.5 V)
Pricing Type
BTO
Carbon Footprint
91.8 kg carbon emissions
Bundled Services
3 years Basic Hardware Service with Advanced Exchange after remote diagnosis
Docking station
20.5 cm
9 cm
3.525 cm
562 g
Video
Max Resolution Details
4K - 60 Hz (Quad Display) , 5K - 60 Hz (Dual Display) , 6K - 60 Hz (Single Display)
Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
2 x display / video - DisplayPort - 20 pin DisplayPort (1.4) , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB-C 3.2 Gen 2/DisplayPort 1.4 - 24 pin USB-C , 1 x USB-C 3.2 Gen 2 - 24 pin USB-C , 4 x USB 3.2 Gen 2 - 9 pin USB Type A , 1 x network - 2.5G Gigabit Ethernet - RJ-45
1 x USB-C cable - integrated - 90 cm
Security lock slot (cable lock sold separately), wake on LAN, Preboot Execution Environment (PXE) support, 3 LED indicators, MAC address pass-through, 130W power delivery to Dell systems, Dell Power Button Sync, Kernel Direct Memory Access (DMA) protection, Remote IT management, remote firmware updates without a PC, 96W power delivery to non-Dell systems
Security Slot Type
Noble Wedge security slot / Kensington security slot
DisplayPort 1.4
Pricing Type
BTO
Sustainability
Carbon Footprint
Manufacturing (kg CO2e)
28.27
Logistics (kg CO2e)
2.02
Use (kg CO2e)
60.5
EOL (kg CO2e)
1.1
Total Carbon w/o Use Phase (kg CO2e)
31.3038
PAIA Version
GaBi version 1, 2025
Power adapter
Power Provided
180 watt
Voltage Provided
19.5 V
Red Hat Enterprise Linux, Google Chrome OS, Windows 10, Windows 11, Ubuntu 24.04
Bundled Services
35 °C
Brand: Dell
