Dell Pro Plus P2725DE 27" 2560x1440 8ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: J7ZPWS00 Mfr#: DELL-P2725DE
More than 50 In Stock
£253.31 ex VAT
£303.97 inc VAT
The Dell Pro 27 Plus QHD USB-C Hub Monitor P2725DE is designed to enhance productivity and connectivity in any workspace. With a 27-inch diagonal display and a native resolution of 2560 x 1440, this monitor provides crisp, vibrant visuals while maintaining a sleek profile. The advanced IPS technology offers wide viewing angles of 178 degrees, ensuring that colors remain consistent from any perspective. The display is complemented by a flicker-free panel and Low Blue Light technology, which helps to reduce eye strain during prolonged use. Featuring an integrated USB 3.2 Gen 1/USB-C hub, this monitor delivers power delivery of up to 90 watts, allowing for efficient charging of connected devices. The built-in Ethernet and multiple interface options, including HDMI, DisplayPort, and USB-C, ensure that connectivity is seamless and versatile. With its ergonomic adjustments for height, tilt, swivel, and rotation, the Dell Pro 27 Plus monitor caters to individual preferences, creating a comfortable and efficient working environment.
  • Vibrant display quality
    The monitor features a native resolution of 2560 x 1440 and a brightness of 350 cd/m2, ensuring vibrant and clear visuals suitable for any task.
  • Versatile connectivity options
    Equipped with HDMI, DisplayPort, and USB-C interfaces, this monitor allows for easy connections to various devices, accommodating different usage scenarios.
  • Enhanced eye comfort
    With Low Blue Light technology and a flicker-free panel, users can enjoy reduced eye strain, making this monitor ideal for long working hours.
  • Dynamic ergonomic design
    The monitor supports height adjustment, tilt, swivel, and pivot functions, allowing users to position it for optimal viewing comfort.
  • Environmentally conscious manufacturing
    The Dell Pro 27 Plus monitor meets EPEAT Gold standards and is ENERGY STAR certified, reflecting its commitment to sustainability and energy efficiency.
Dell Pro Plus P2725DE - LED monitor - QHD - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/2173563
Energy Class
Class E
Power Consumption (On mode)
19.6 W
USB 3.2 Gen 1/USB-C hub, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 100 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1500:1
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB (CIE 1931)
Input Connectors
HDMI, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (highest position)
61.25 cm x 19.216 cm x 53.57 cm
6.59 kg
Pricing Type
BTO
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
218 kg carbon emissions
Plug and Play, RoHS, BFR-free, DisplayPort 1.4, HDCP 1.4, PVC-free, TUV Rheinland Eye Comfort Certification (4-star)
Bundled Services
3 years Basic Hardware Service with Advanced Exchange after remote diagnosis
Display Type
Energy Class
Class E
Diagonal Size
27"
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
1500:1
Colour Support
Colour Gamut
99% sRGB (CIE 1931)
Response Time
Vertical Refresh Rate
48 - 100 Hz
Horizontal Refresh Rate
30 - 151 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Mercury free, arsenic-free glass, Dell Easy Arrange, Wide Viewing Angle, Low Blue Light technology, 3-sided bezeless, Dell ComfortView Plus, flicker-free panel
61.25 cm x 19.216 cm x 53.57 cm - with stand (highest position)
6.59 kg
HDMI (HDCP 1.4) , DisplayPort 1.4 (HDCP 1.4) , DisplayPort output (HDCP 1.4, MST) , USB-C upstream/DisplayPort 1.4 Alt Mode with Power Delivery (power up to 90W) , USB-C 3.2 downstream with Power Charging (power up to 15W) , 3 x USB 3.2 Gen 1 downstream , LAN (RJ-45)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
Cable tie
1 x DisplayPort 1.4 cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C 3.2 Gen 1 cable - USB-C - 1 m , 1 x USB-C 3.2 Gen 1 cable - USB Type C to A - 1.8 m
Pricing Type
BTO
Security Slot Type
Kensington security slot
Input Voltage
19.6 W
20 kWh/1000h
Power Consumption (Typical)
20 Watt
Power Consumption (Max)
200 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (lowest position) - width: 61.25 cm - depth: 19.216 cm - height: 38.57 cm - weight: 6.59 kg , With stand (highest position) - width: 61.25 cm - depth: 19.216 cm - height: 53.57 cm - weight: 6.59 kg , Without stand - width: 61.25 cm - depth: 4.99 cm - height: 35.655 cm - weight: 4.6 kg
Shipping Weight
8.93 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
ENERGY STAR Version
8.0
Carbon Footprint
Manufacturing (kg CO2e)
95.92
Logistics (kg CO2e)
16.79
Use (kg CO2e)
95.92
EOL (kg CO2e)
9.37
Total Carbon w/o Use Phase (kg CO2e)
122.08
PAIA Version
GaBi version 1
Bundled Services
10 - 80% (non-condensing)
J7ZP Dell Dual Monitor Stand - MDS19 In Stock £174.65
Brand: Dell
