The Dell Pro 27 Plus QHD USB-C Hub Monitor P2725DE is designed to enhance productivity and connectivity in any workspace. With a 27-inch diagonal display and a native resolution of 2560 x 1440, this monitor provides crisp, vibrant visuals while maintaining a sleek profile. The advanced IPS technology offers wide viewing angles of 178 degrees, ensuring that colors remain consistent from any perspective. The display is complemented by a flicker-free panel and Low Blue Light technology, which helps to reduce eye strain during prolonged use. Featuring an integrated USB 3.2 Gen 1/USB-C hub, this monitor delivers power delivery of up to 90 watts, allowing for efficient charging of connected devices. The built-in Ethernet and multiple interface options, including HDMI, DisplayPort, and USB-C, ensure that connectivity is seamless and versatile. With its ergonomic adjustments for height, tilt, swivel, and rotation, the Dell Pro 27 Plus monitor caters to individual preferences, creating a comfortable and efficient working environment.
Vibrant display quality
The monitor features a native resolution of 2560 x 1440 and a brightness of 350 cd/m2, ensuring vibrant and clear visuals suitable for any task. -
Versatile connectivity options
Equipped with HDMI, DisplayPort, and USB-C interfaces, this monitor allows for easy connections to various devices, accommodating different usage scenarios. -
Enhanced eye comfort
With Low Blue Light technology and a flicker-free panel, users can enjoy reduced eye strain, making this monitor ideal for long working hours. -
Dynamic ergonomic design
The monitor supports height adjustment, tilt, swivel, and pivot functions, allowing users to position it for optimal viewing comfort. -
Environmentally conscious manufacturing
The Dell Pro 27 Plus monitor meets EPEAT Gold standards and is ENERGY STAR certified, reflecting its commitment to sustainability and energy efficiency.
- Dell Pro Plus P2725DE - LED monitor - QHD - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/2173563
- Energy Class
- Class E
- Power Consumption (On mode)
- 19.6 W
- USB 3.2 Gen 1/USB-C hub, USB PD 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 100 Hz
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1500:1
- Response Time
- 5 ms (fast), 8 ms (normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB (CIE 1931)
- Input Connectors
- HDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 100-240 V (50/60 Hz)
- Dimensions (WxDxH) - with stand (highest position)
- 61.25 cm x 19.216 cm x 53.57 cm
- 6.59 kg
- Pricing Type
- BTO
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 218 kg carbon emissions
- Plug and Play, RoHS, BFR-free, DisplayPort 1.4, HDCP 1.4, PVC-free, TUV Rheinland Eye Comfort Certification (4-star)
- Bundled Services
- 3 years Basic Hardware Service with Advanced Exchange after remote diagnosis
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 27"
- Built-in Devices
- USB Power Delivery
- 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2331 mm
- Pixel Per Inch
- 109
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1500:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 48 - 100 Hz
- Horizontal Refresh Rate
- 30 - 151 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- LED edgelight system, Mercury free, arsenic-free glass, Dell Easy Arrange, Wide Viewing Angle, Low Blue Light technology, 3-sided bezeless, Dell ComfortView Plus, flicker-free panel
- 61.25 cm x 19.216 cm x 53.57 cm - with stand (highest position)
- 6.59 kg
- HDMI (HDCP 1.4) , DisplayPort 1.4 (HDCP 1.4) , DisplayPort output (HDCP 1.4, MST) , USB-C upstream/DisplayPort 1.4 Alt Mode with Power Delivery (power up to 90W) , USB-C 3.2 downstream with Power Charging (power up to 15W) , 3 x USB 3.2 Gen 1 downstream , LAN (RJ-45)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
- Included Accessories
- Cable tie
- Cables Included
- 1 x DisplayPort 1.4 cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C 3.2 Gen 1 cable - USB-C - 1 m , 1 x USB-C 3.2 Gen 1 cable - USB Type C to A - 1.8 m
- Pricing Type
- BTO
- Security Slot Type
- Kensington security slot
- Input Voltage
- 19.6 W
- Power Consumption SDR (On mode)
- 20 kWh/1000h
- Power Consumption (Typical)
- 20 Watt
- Power Consumption (Max)
- 200 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand (lowest position) - width: 61.25 cm - depth: 19.216 cm - height: 38.57 cm - weight: 6.59 kg , With stand (highest position) - width: 61.25 cm - depth: 19.216 cm - height: 53.57 cm - weight: 6.59 kg , Without stand - width: 61.25 cm - depth: 4.99 cm - height: 35.655 cm - weight: 4.6 kg
- Shipping Weight
- 8.93 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Carbon Footprint
- Manufacturing (kg CO2e)
- 95.92
- Logistics (kg CO2e)
- 16.79
- Use (kg CO2e)
- 95.92
- EOL (kg CO2e)
- 9.37
- Total Carbon w/o Use Phase (kg CO2e)
- 122.08
- PAIA Version
- GaBi version 1
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Dell Dual Monitor Stand - MDS19 | In Stock | £166.38 |
