Dell Pro Plus P2425D 24" 2560x1440 5ms HDMI DisplayPort IPS LED Monitor
Quicklinx: J8F2WS00 Mfr#: DELL-P2425D
More than 50 In Stock
£155.74 ex VAT
£186.88 inc VAT
The Dell Pro 24 Plus QHD Monitor P2425D is designed to enhance productivity and provide a visual experience. With a 23.8-inch viewable screen and a native resolution of 2560 x 1440, this monitor delivers crisp and clear images with a vibrant color spectrum made possible by 16.7 million colors and 99% sRGB color coverage. The monitor's LED backlight technology ensures brightness levels of up to 350 cd/m², along with a contrast ratio of 1500:1, making it ideal for both work and entertainment. Additionally, the anti-glare coating allows comfortable viewing in various lighting conditions, while the flicker-free panel and Low Blue Light technology help reduce eye strain during extended use. With versatile ergonomic adjustments, including height, swivel, pivot, and tilt features, users can customize their viewing experience. The built-in USB 3.2 Gen 1 hub extends connectivity options, allowing for seamless integration with various devices. The monitor's design features a 3-sided bezeless display and integrated cable management to keep workspaces tidy. Certified with EPEAT Gold and ENERGY STAR, this monitor prioritizes environmental standards while delivering performance and style.
Dell Pro Plus P2425D - LED monitor - QHD - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/2151579
Energy Class
Class E
Power Consumption (On mode)
15.6 W
USB 3.2 Gen 1 hub, USB PD 15 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 100 Hz
Pixel Pitch
0.2058 mm
Brightness
350 cd/m²
Contrast Ratio
1500:1
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB (CIE 1931)
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (highest position)
53.87 cm x 18.154 cm x 49.655 cm
5.08 kg
Pricing Type
BTO
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
175 kg carbon emissions
Plug and Play, RoHS, BFR-free, DisplayPort 1.4, HDCP 1.4, PVC-free, TUV Rheinland Eye Comfort Certification (4-star)
Bundled Services
3 years Basic Hardware Service with Advanced Exchange after remote diagnosis
Display Type
Energy Class
Class E
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 3.2 Gen 1 hub
USB Power Delivery
15 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2058 mm
Pixel Per Inch
123
Brightness
350 cd/m²
Contrast Ratio
1500:1
Colour Support
Colour Gamut
99% sRGB (CIE 1931)
Response Time
Vertical Refresh Rate
48 - 100 Hz
Horizontal Refresh Rate
30 - 150 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Mercury free, arsenic-free glass, Dell Easy Arrange, Wide Viewing Angle, Low Blue Light technology, 3-sided bezeless, Dell ComfortView Plus, flicker-free panel
53.87 cm x 18.154 cm x 49.655 cm - with stand (highest position)
5.08 kg
DisplayPort 1.4 (HDCP 1.4) , HDMI (HDCP 1.4) , USB 3.2 Gen 1 upstream (Type B) , 3 x USB 3.2 Gen 1 downstream (Type A) , USB-C 3.2 downstream with Power Charging (power up to 15W)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
1 x DisplayPort 1.4 cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable - USB Type A to B - 1.8 m
Pricing Type
BTO
Security Slot Type
Kensington security slot
Input Voltage
15.6 W
16 kWh/1000h
Power Consumption (Typical)
15.9 Watt
Power Consumption (Max)
75 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (lowest position) - width: 53.87 cm - depth: 18.154 cm - height: 36.4 cm - weight: 5.08 kg , With stand (highest position) - width: 53.87 cm - depth: 18.154 cm - height: 49.655 cm - weight: 5.08 kg , Without stand - width: 53.87 cm - depth: 4.974 cm - height: 31.525 cm - weight: 3.2 kg
Shipping Weight
7.04 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
ENERGY STAR Version
8.0
Carbon Footprint
Manufacturing (kg CO2e)
80.85
Logistics (kg CO2e)
13.3
Use (kg CO2e)
76.65
EOL (kg CO2e)
4.2
Total Carbon w/o Use Phase (kg CO2e)
98.35
PAIA Version
GaBi version 1
Bundled Services
10 - 80% (non-condensing)
Brand: Dell
