Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black
Quicklinx: GG2BWS00 Mfr#: KM5221WBKB-UK
Recommended Use: Leisure
Type: Keyboard, Mouse
Wired / Wireless: Wireless
Colour: Black
Compatibility: Mac, PC, Android
More than 50 In Stock
£27.49 ex VAT
£32.98 inc VAT
Combining a discreetly powerful keyboard with an expertly designed mouse, the Dell Pro Wireless Keyboard and Mouse combo enhances your productivity. Powered by one of the industry's leading battery lives of up to 36 months, this combo is built to last.
  • Productivity at your fingertips
    Enhance your all-day productivity with this RF 2.4GHz wireless keyboard and mouse combo. With 12 programmable keys and 1 programmable scroll wheel click, you can gain quick access to your frequently used applications, folders and functions. The full-sized wireless keyboard comes with a dedicated numeric pad, function keys, and programmed pre-sets that can enhance your efficiency.
  • Easy management
    Easily navigate across monitors of varying resolutions at home or in the office. Dell Peripheral Manager (DPM) software enables you to manage your input devices and adjust to your preferred preset DPIs at 1000, 1600, 2400, or 4000. With DPM, you can customize shortcut keys and buttons, pair devices, adjust DPI, check battery and connectivity status, and update to the latest firmware.
  • Work in comfort
    Work with one of the quietest wireless keyboards whether on a conference call or in proximity with others. Symmetrically designed, the wireless mouse is great for both left and right-handed users. The tilt legs offer two adjustable angles for the keyboard, giving you the flexibility to choose your preferred typing position.
  • Durable and secure
    The Dell Pro Wireless Keyboard and Mouse is built to last with one of the industry's leading battery lives at up to 36 months. Rest assured that this keyboard and mouse combo has been rigorously tested to ensure seamless connection to your Dell PC. The keyboard offers 128-bit AES (Advanced Encryption Standard) encryption protecting your data transmission across your PCs and devices, providing you with a secure connection while typing.
Dell Pro KM5221W - keyboard and mouse set - QWERTY - UK - black
Keyboard and mouse set
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
QWERTY UK
Hot Keys Function
Volume, mute
Pointing Device
Mouse - wireless - optical
Buttons Qty
3
3-year warranty
Vostro 15 3515; XPS 15 9510
2.4 GHz
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 43.2 cm x 12.2 cm x 3.3 cm / 400 g , Mouse: 11.4 cm x 3.81 cm / 90.7 g
Input Device
Wireless
Hot Keys Function
Volume, mute
QWERTY UK
Pointing Device
Mouse - wireless
Buttons Qty
3
Movement Detection Technology
Optical
Movement Resolution
4000 dpi
Batteries:
1
Supported Battery Type
AA x 1
AA battery, 2 AAA batteries
AES-128
Included Software
Dell Peripheral Manager (Windows only)
Apple MacOS, Android, Google Chrome OS, Microsoft Windows 7 / 8.1 / 10, Red Hat Enterprise Linux 8.0, Ubuntu 18.04
AAA type
Installed Qty
2
Limited warranty - advanced exchange programme - 3 years
Dell Vostro 15 3515 , Dell XPS 15 9510
Type: Keyboard
Type: Mouse
Colour: Black
Compatibility: Mac
Compatibility: PC
Compatibility: Android
Brand: Dell
