Dell Pro E2725HM 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: JFG8WS00 Mfr#: DELL-E2725HM
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£91.00 ex VAT
£109.20 inc VAT
The Dell Pro E2725HM is designed to elevate the desktop experience with its 27-inch Full HD display. Featuring a native resolution of 1920 x 1080, this monitor delivers clarity and detail characterized by its 300 cd/m² brightness and a contrast ratio of 1000:1. With a wide horizontal and vertical viewing angle of 178 degrees, users can enjoy vibrant colors and clear images from almost any position. Various features like Dell Easy Arrange and Eye Comfort Mode make managing multiple applications and ensuring visual comfort effortless. The anti-glare and 3H hard coating help reduce reflections, making it suitable for extended use. Additionally, the monitor supports advanced connectivity options through its DisplayPort, HDMI, and VGA inputs while maintaining a sleek design with a 3-sided bezel-less screen.
Dell Pro E2725HM - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/2186816
Energy Class
Class D
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 100 Hz, HDMI: 100 Hz, VGA: 60 Hz)
Pixel Pitch
0.3114 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC (CIE 1931)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
61.11 cm x 18.829 cm x 45.431 cm
4.55 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
171 kg carbon emissions
Plug and Play, RoHS, NFPA 99, DisplayPort 1.2, HDCP 1.4, BFR-reduced, PVC-reduced, TUV Rheinland Eye Comfort Certification (3-star)
Bundled Services
3 years Basic Hardware Service with Advanced Exchange
Display Type
Energy Class
Class D
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Pixel Per Inch
81
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% NTSC (CIE 1931)
Response Time
Vertical Refresh Rate
48 - 100 Hz
Horizontal Refresh Rate
30 - 110 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Eye comfort mode, 3-sided bezeless, Dell ComfortView Plus
61.11 cm x 18.829 cm x 45.431 cm - with stand
4.55 kg
HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , VGA
Mechanical
Tilt
Tilt Angle
-5/+21
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, cable management system
1 x DisplayPort 1.2 cable - DisplayPort to DisplayPort - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
15 kWh/1000h
Power Consumption (Typical)
14.76 watt
Power Consumption (Max)
28 watt
Power Consumption Stand by
0.3 watt
Power Consumption (Off Mode)
0.3 watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand - width: 61.11 cm - depth: 18.829 cm - height: 45.431 cm - weight: 4.55 kg , Without stand - width: 61.11 cm - depth: 4.922 cm - height: 36.186 cm - weight: 3.57 kg
Shipping Weight
6.69 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
ENERGY STAR Version
8.0
Carbon Footprint
Manufacturing (kg CO2e)
81.23
Logistics (kg CO2e)
12.48
Use (kg CO2e)
72.85
EOL (kg CO2e)
4.28
Total Carbon w/o Use Phase (kg CO2e)
98.154
PAIA Version
GaBi version 1, 2024
Bundled Services
10 - 80% (non-condensing)
JFG8 Dell Dual Monitor Stand - MDS19 In Stock £130.16
Diagonal Size: 27in
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Dell
