Dell Pro E2425HSM 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: J8XQWS00 Mfr#: DELL-E2425HSM
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: VGA (HD-15), DisplayPort, HDMI
£91.63 ex VAT
£109.95 inc VAT
The Dell Pro E2425HSM offers a 24-inch display with a viewable size of 23.8 inches, delivering Full HD resolution at 1920 x 1080 pixels. The monitor features a brightness of 250 cd/m2 and a contrast ratio of 1000:1, ensuring images appear vibrant and detailed. With an anti-glare coating and a wide viewing angle of 178 degrees both horizontally and vertically, this display is suitable for various working environments, reducing reflections and maintaining picture clarity from different positions.
Designed for comfort and convenience, the E2425HSM includes multiple display position adjustments, including height adjustment, pivot, swivel, and tilt, allowing users to achieve a comfortable viewing angle. Additionally, Dell ComfortView Plus reduces harmful blue light emission, minimizing eye strain during extended use. EPEAT Gold certified and ENERGY STAR certified, this monitor is effective and environmentally friendly, making it a solid choice for any workspace.
Dell Pro E2425HSM - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/2193019
Energy Class
Class D
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 100 Hz, HDMI: 100 Hz, VGA: 60 Hz)
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC (CIE 1931)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (highest position)
53.864 cm x 21.16 cm x 48.577 cm
4.66 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
151 kg carbon emissions
Plug and Play, RoHS, NFPA 99, DisplayPort 1.2, HDCP 1.4, BFR-reduced, PVC-reduced, TUV Rheinland Eye Comfort Certification (3-star)
Bundled Services
3 years Basic Hardware Service with Advanced Exchange
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% NTSC (CIE 1931)
Response Time
Vertical Refresh Rate
50 - 100 Hz
Horizontal Refresh Rate
30 - 110 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Eye comfort mode, 3-sided bezeless, Dell ComfortView Plus
53.864 cm x 21.16 cm x 48.577 cm - with stand (highest position)
4.66 kg
Audio
Speakers - stereo
Output Power / Channel
2 watt
HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , VGA
Mechanical
Tilt Angle
-5/+21
Swivel Angle
346
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, cable management system
1 x HDMI cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
12 kWh/1000h
Power Consumption (Typical)
11.94 watt
Power Consumption (Max)
28.5 watt
Power Consumption Stand by
0.3 watt
Power Consumption (Off Mode)
0.3 watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (lowest position) - width: 53.864 cm - depth: 21.16 cm - height: 35.577 cm - weight: 4.66 kg , With stand (highest position) - width: 53.864 cm - depth: 21.16 cm - height: 48.577 cm - weight: 4.66 kg , Without stand - width: 53.864 cm - depth: 5.354 cm - height: 32.421 cm - weight: 2.81 kg
Shipping Weight
6.56 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
ENERGY STAR Version
8.0
Carbon Footprint
Manufacturing (kg CO2e)
75.35
Logistics (kg CO2e)
12.38
Use (kg CO2e)
59.8
EOL (kg CO2e)
3.47
Total Carbon w/o Use Phase (kg CO2e)
91.204
PAIA Version
GaBi version 1, 2024
Bundled Services
10 - 80% (non-condensing)
J8XQ Dell Dual Monitor Stand - MDS19 In Stock £109.85
Diagonal Size: 24in
Response Time: 5ms
Interfaces: DisplayPort
Interfaces: HDMI
Brand: Dell
