The Dell Pro E2425HSM offers a 24-inch display with a viewable size of 23.8 inches, delivering Full HD resolution at 1920 x 1080 pixels. The monitor features a brightness of 250 cd/m2 and a contrast ratio of 1000:1, ensuring images appear vibrant and detailed. With an anti-glare coating and a wide viewing angle of 178 degrees both horizontally and vertically, this display is suitable for various working environments, reducing reflections and maintaining picture clarity from different positions.
Designed for comfort and convenience, the E2425HSM includes multiple display position adjustments, including height adjustment, pivot, swivel, and tilt, allowing users to achieve a comfortable viewing angle. Additionally, Dell ComfortView Plus reduces harmful blue light emission, minimizing eye strain during extended use. EPEAT Gold certified and ENERGY STAR certified, this monitor is effective and environmentally friendly, making it a solid choice for any workspace.
- Dell Pro E2425HSM - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/2193019
- Energy Class
- Class D
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 (DisplayPort: 100 Hz, HDMI: 100 Hz, VGA: 60 Hz)
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC (CIE 1931)
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 100-240 V (50/60 Hz)
- Dimensions (WxDxH) - with stand (highest position)
- 53.864 cm x 21.16 cm x 48.577 cm
- 4.66 kg
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 151 kg carbon emissions
- Plug and Play, RoHS, NFPA 99, DisplayPort 1.2, HDCP 1.4, BFR-reduced, PVC-reduced, TUV Rheinland Eye Comfort Certification (3-star)
- Bundled Services
- 3 years Basic Hardware Service with Advanced Exchange
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 50 - 100 Hz
- Horizontal Refresh Rate
- 30 - 110 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Eye comfort mode, 3-sided bezeless, Dell ComfortView Plus
- 53.864 cm x 21.16 cm x 48.577 cm - with stand (highest position)
- 4.66 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 watt
- HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , VGA
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 346
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support, cable management system
- Cables Included
- 1 x HDMI cable - 1.8 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 12 kWh/1000h
- Power Consumption (Typical)
- 11.94 watt
- Power Consumption (Max)
- 28.5 watt
- Power Consumption Stand by
- 0.3 watt
- 0.3 watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand (lowest position) - width: 53.864 cm - depth: 21.16 cm - height: 35.577 cm - weight: 4.66 kg , With stand (highest position) - width: 53.864 cm - depth: 21.16 cm - height: 48.577 cm - weight: 4.66 kg , Without stand - width: 53.864 cm - depth: 5.354 cm - height: 32.421 cm - weight: 2.81 kg
- Shipping Weight
- 6.56 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Carbon Footprint
- Manufacturing (kg CO2e)
- 75.35
- Logistics (kg CO2e)
- 12.38
- Use (kg CO2e)
- 59.8
- EOL (kg CO2e)
- 3.47
- Total Carbon w/o Use Phase (kg CO2e)
- 91.204
- PAIA Version
- GaBi version 1, 2024
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Dell Dual Monitor Stand - MDS19 | In Stock | £124.85 |
