The Dell Pro E2425HM is designed to elevate your desktop experience with its 24-inch display. Offering a native resolution of 1920 x 1080, this monitor delivers clear images, thanks to its TFT active matrix technology and LED edgelight system. The anti-glare coating reduces reflections, making it suitable for various lighting conditions. With a response time of 5 ms and a refresh rate of 100 Hz, fast-paced visuals appear smooth, enhancing gaming and media consumption. Furthermore, the VESA interface support and cable management system create a neat workspace.
Experience vivid colors with 16.7 million color support and a color gamut of 72% NTSC. The monitor's ergonomic features include tilt adjustments for comfortable viewing angles during extended work sessions. Eye comfort is prioritized with Dell ComfortView Plus and Flicker-Free technology, significantly reducing eye strain. With Energy STAR certification and EPEAT Gold compliance, the Dell Pro E2425HM is an environmentally friendly choice, allowing users to be mindful of their carbon footprint while enjoying high-quality visuals.
Stunning visuals
The E2425HM features a 23.8-inch viewable display with a pixel pitch of 0.2745 mm, providing sharp and detailed images. With an image brightness of 250 cd/m2 and a contrast ratio of 1000:1, users can expect clear visuals in various lighting conditions. -
Advanced connectivity options
Equipped with multiple input options including DisplayPort, HDMI, and VGA, this monitor ensures compatibility with various devices. The Plug-and-Play compliance simplifies connection, making setup quick and easy. -
Ergonomic design
The monitor supports a tilt angle of -5 to +21 degrees, allowing users to adjust the screen to their preferred eye level for comfort during extended use. Its 3-sided bezel-less design maximizes screen area. -
Environmentally conscious
Certified with ENERGY STAR and EPEAT Gold standards, the monitor promotes energy efficiency. Additionally, it features mercury-free components and arsenic-free glass, aligning with eco-friendly practices.
- Dell Pro E2425HM - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/2192921
- Energy Class
- Class D
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 (DisplayPort: 100 Hz, HDMI: 100 Hz, VGA: 60 Hz)
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC (CIE 1931)
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 100-240 V (50/60 Hz)
- 53.864 cm x 17.1 cm x 41.235 cm
- 3.6 kg
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 149 kg carbon emissions
- Plug and Play, RoHS, NFPA 99, DisplayPort 1.2, HDCP 1.4, BFR-reduced, PVC-reduced, TUV Rheinland Eye Comfort Certification (3-star)
- Bundled Services
- 3 years Basic Hardware Service with Advanced Exchange
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 50 - 100 Hz
- Horizontal Refresh Rate
- 30 - 110 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Eye comfort mode, 3-sided bezeless, Dell ComfortView Plus
- 53.864 cm x 17.1 cm x 41.235 cm - with stand
- 3.6 kg
- HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support, cable management system
- Cables Included
- 1 x DisplayPort 1.2 cable - DisplayPort to DisplayPort - 1.8 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 14 kWh/1000h
- Power Consumption (Typical)
- 12.1 watt
- Power Consumption (Max)
- 28.5 watt
- Power Consumption Stand by
- 0.3 watt
- 0.3 watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 53.864 cm - depth: 17.1 cm - height: 41.235 cm - weight: 3.6 kg , Without stand - width: 53.864 cm - depth: 4.77 cm - height: 32.421 cm - weight: 2.81 kg
- Shipping Weight
- 5.18 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Carbon Footprint
- Manufacturing (kg CO2e)
- 66.6
- Logistics (kg CO2e)
- 9.69
- Use (kg CO2e)
- 70.33
- EOL (kg CO2e)
- 2.24
- Total Carbon w/o Use Phase (kg CO2e)
- 78.672
- PAIA Version
- GaBi version 1, 2024
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Dell Dual Monitor Stand - MDS19 | In Stock | £109.85 |
