Dell Pro E2425HM 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: J67JWS00 Mfr#: DELL-E2425HM
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: DisplayPort, HDMI, VGA (HD-15)
29 In Stock
£67.48 ex VAT
£80.97 inc VAT
The Dell Pro E2425HM is designed to elevate your desktop experience with its 24-inch display. Offering a native resolution of 1920 x 1080, this monitor delivers clear images, thanks to its TFT active matrix technology and LED edgelight system. The anti-glare coating reduces reflections, making it suitable for various lighting conditions. With a response time of 5 ms and a refresh rate of 100 Hz, fast-paced visuals appear smooth, enhancing gaming and media consumption. Furthermore, the VESA interface support and cable management system create a neat workspace.
Experience vivid colors with 16.7 million color support and a color gamut of 72% NTSC. The monitor's ergonomic features include tilt adjustments for comfortable viewing angles during extended work sessions. Eye comfort is prioritized with Dell ComfortView Plus and Flicker-Free technology, significantly reducing eye strain. With Energy STAR certification and EPEAT Gold compliance, the Dell Pro E2425HM is an environmentally friendly choice, allowing users to be mindful of their carbon footprint while enjoying high-quality visuals.
  • Stunning visuals
    The E2425HM features a 23.8-inch viewable display with a pixel pitch of 0.2745 mm, providing sharp and detailed images. With an image brightness of 250 cd/m2 and a contrast ratio of 1000:1, users can expect clear visuals in various lighting conditions.
  • Advanced connectivity options
    Equipped with multiple input options including DisplayPort, HDMI, and VGA, this monitor ensures compatibility with various devices. The Plug-and-Play compliance simplifies connection, making setup quick and easy.
  • Ergonomic design
    The monitor supports a tilt angle of -5 to +21 degrees, allowing users to adjust the screen to their preferred eye level for comfort during extended use. Its 3-sided bezel-less design maximizes screen area.
  • Environmentally conscious
    Certified with ENERGY STAR and EPEAT Gold standards, the monitor promotes energy efficiency. Additionally, it features mercury-free components and arsenic-free glass, aligning with eco-friendly practices.
Dell Pro E2425HM - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/2192921
Energy Class
Class D
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 100 Hz, HDMI: 100 Hz, VGA: 60 Hz)
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC (CIE 1931)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
53.864 cm x 17.1 cm x 41.235 cm
3.6 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
149 kg carbon emissions
Plug and Play, RoHS, NFPA 99, DisplayPort 1.2, HDCP 1.4, BFR-reduced, PVC-reduced, TUV Rheinland Eye Comfort Certification (3-star)
Bundled Services
3 years Basic Hardware Service with Advanced Exchange
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% NTSC (CIE 1931)
Response Time
Vertical Refresh Rate
50 - 100 Hz
Horizontal Refresh Rate
30 - 110 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Eye comfort mode, 3-sided bezeless, Dell ComfortView Plus
53.864 cm x 17.1 cm x 41.235 cm - with stand
3.6 kg
HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , VGA
Mechanical
Tilt
Tilt Angle
-5/+21
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, cable management system
1 x DisplayPort 1.2 cable - DisplayPort to DisplayPort - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
14 kWh/1000h
Power Consumption (Typical)
12.1 watt
Power Consumption (Max)
28.5 watt
Power Consumption Stand by
0.3 watt
Power Consumption (Off Mode)
0.3 watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand - width: 53.864 cm - depth: 17.1 cm - height: 41.235 cm - weight: 3.6 kg , Without stand - width: 53.864 cm - depth: 4.77 cm - height: 32.421 cm - weight: 2.81 kg
Shipping Weight
5.18 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
ENERGY STAR Version
8.0
Carbon Footprint
Manufacturing (kg CO2e)
66.6
Logistics (kg CO2e)
9.69
Use (kg CO2e)
70.33
EOL (kg CO2e)
2.24
Total Carbon w/o Use Phase (kg CO2e)
78.672
PAIA Version
GaBi version 1, 2024
Bundled Services
10 - 80% (non-condensing)
J67J Dell Dual Monitor Stand - MDS19 In Stock £130.16
Diagonal Size: 24in
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Dell
