The Dell Pro 16 PC16250 is designed for those who seek enhanced performance and audiovisual experiences. With a 16-inch Full HD Plus display featuring IPS technology, this notebook delivers vibrant images and rich colors. It is ideal for both work and entertainment, offering a native resolution of 1920 x 1200 and an image brightness of 300 cd/m². The anti-glare finish allows for comfortable viewing across various lighting conditions. Equipped with audio capabilities, the dual array microphones and high definition audio enhance communication while the stereo speakers amplify entertainment moments. The device includes a webcam with face recognition, ensuring clear video conferencing. These features combined with a powerful Intel Core Ultra 5 processor provide seamless multitasking and efficient performance, making it a reliable choice for professionals and creatives.
- Dell Pro 16 PC16250 - AI PC - 16" - Intel Core Ultra 5 - 235U - vPro Enterprise - 16 GB RAM - 512 GB SSD
- Product Type
- Notebook - AI PC
- Operating System
- Win 11 Pro
- Platform Technology
- Intel vPro Enterprise
- Processor
- Intel Core Ultra 5 (Series 2) - 235U / 2 GHz, up to 4.9 GHz / 12 MB Cache
- Neural Processor Unit (NPU)
- Intel AI Boost - up to 12 TOPS
- Memory
- 16 GB DDR5 (1 x 16 GB)
- Storage
- 512 GB SSD - NVMe
- Display
- 16" 1920 x 1200 / Full HD Plus @ 60 Hz - 141 ppi
- Graphics
- Intel Graphics
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Gigabit Ethernet
- Battery
- 3-cell
- Security
- Discrete Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Platinum silver
- 35.8 cm x 25.182 cm x 2.085 cm
- 1.92 kg
- Pricing Type
- Build To Stock (BTS)
- Manufacturer Selling Program
- Dell Smart Selection
- Environmental Standards
- EPEAT Gold
- Carbon Footprint
- 108 kg carbon emissions
- Specific Absorption Rate (SAR)
- 1.45 W/kg (body) , 1.45 W/kg (limb)
- Bundled Services
- 1 Year Basic Onsite
- Product Type
- Notebook
- AI Level
- AI PC
- Operating System
- Windows 11 Pro
Processor / Chipset
- CPU
- Intel Core Ultra 5 (Series 2) 235U / 2 GHz
- Max Turbo Speed
- 4.9 GHz
- Number of Cores
- 12-core
- Performance Cores
- 2
- Efficient Cores
- 10
- Cache
- 12 MB
- 14 Threads
- Intel AI Boost
- NPU Performance Up To (TOPS)
- 12 TOPS
- AI Datatype Support on NPU
- INT8
- Sparsity Support
- AI Software Frameworks Supported by NPU
- DirectML, OpenVINO, WindowsML, ONNX RT
- Windows Studio Effects Support
- RAM
- 16 GB (1 x 16 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR5 SDRAM
- Speed
- 5600 MT/s
- Rated Speed
- 5600 MT/s
- Form Factor
- SO-DIMM 262-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 512 GB SSD M.2 2230 PCIe 4.0 - NVM Express (NVMe)
Display
- 16" - IPS
- Resolution
- 1920 x 1200 (Full HD Plus)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Pixel Density (ppi)
- 141
- Image Aspect Ratio
- 16:10
- Image Brightness
- 300 cd/m²
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +85 / -85
- Colour Gamut
- 45% NTSC
- Anti-glare, 35 ms response rate, 0.1795 mm pixel pitch
Audio & Video
- Graphics Processor
- Intel Graphics
- Camera
- Yes - 1920 x 1080 (standard), 640 x 360 (infrared)
- Resolution
- 2.07 Megapixel (standard), 0.23 Megapixel (infrared)
- Image Sensor Type
- CMOS
- Video Resolutions
- 1920 x 1080
- Frame Rate
- 30 frames per second
- Camera Features
- Face recognition, IR camera, RGB camera, Temporal Noise Reduction, 86.6 degrees (IR camera), 80.2 degrees, camera shutter
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3204
- High Definition Audio, Wave MAXXAudio Pro
Input
- Keyboard, touchpad
- Numeric Keypad
- Copilot key
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6E AX 211 - M.2 2230
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Realtek RTL8111H-CG
- Dual stream (2x2)
- Technology
- 3-cell
- 210 g
- Capacity
- 55 Wh
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 65 watt, 5/9/15/20 V
Connections & Expansion
- Interfaces Details
- HDMI , USB-C 3.2 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , USB4 (supports Thunderbolt 4, DisplayPort Alt Mode) (Power Delivery) , USB 3.2 Gen 1 , USB 3.2 Gen 1 (PowerShare) , LAN (RJ-45) , Headphone/microphone combo jack
Software
- Software Included
- Intel Rapid Storage Technology, Intel Connectivity Performance Suite, Dell Additional Softwares, Activate your Microsoft 365 for a 30 day trial
- Platinum silver
- Surface Finish
- Metallic
- Security
- ExpressCharge, ExpressChargeBoost
- Theft/Intrusion Protection
- Security Slot Type
- Wedge-shaped security slot
- Included Accessories
- USB-C power adapter, POD Label
- FIPS 140-2, TCG Certified
- Pricing Type
- 1.92 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- Carbon Footprint
- Manufacturing (kg CO2e)
- 70.416
- Logistics (kg CO2e)
- 6.048
- Use (kg CO2e)
- 28.512
- EOL (kg CO2e)
- 3.02
- Total Carbon w/o Use Phase (kg CO2e)
- 90
- PAIA Version
- GaBi version 1, 2024
- Bundled Services
- 0 °C
- 40 °C
- 90% (non-condensing)
- Shock Tolerance (operating)
- 140 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.66 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
Dell Pro Dock WD25 - docking station - USB-C - HDMI, 2 x DP, USB-C - 1GbE, 2.5GbE | In Stock | £148.54 |
Dell Pro Smart Dock SD25 - docking station - USB-C - HDMI, 2 x DP, USB-C - 1GbE, 2.5GbE | In Stock | £206.78 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
Dell Upgrade from 1Y Basic Onsite to 3Y Basic Onsite - 2 years - 2nd/3rd year - on-site | In Stock | £38.63 |
Other bundles (28)
Dell Slim DW316 USB External DVD Drive | In Stock | £40.60 |
Dell MS116 Mouse Optical Wired USB Black For Lattitude | In Stock | £8.69 |
Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 | In Stock | £12.80 |
Dell Dell KB-522 Wired Business Multimedia USB Keyboard - Black | In Stock | £23.31 |
Dell KB-813 Smart Card Reader | In Stock | £32.06 |
Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey | In Stock | £44.32 |
Dell SB521A Magnetic Sound bar | In Stock | £30.78 |
Dell MS5120W Mobile Pro Wireless Mouse | In Stock | £26.00 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £44.78 |
Dell Dual Monitor Stand - MDS19 | In Stock | £129.07 |
Dell Multi-Device KB700 - Keyboard - wireless - 2.4 GHz, Bluetoot | In Stock | £48.55 |
Dell WEBCAM - WB3023 | In Stock | £47.02 |
Dell Dell Mobile Wireless Mouse - MS3320W - Black | In Stock | £15.38 |
Dell Dell Speakerphone SP3022 | In Stock | £63.32 |
Dell UltraSharp 24" 1920 x 1080 5 ms IPS | In Stock | £157.91 |
Dell 27" P2724DEB 2560x1440 5ms HDMI DisplayPort USB-C Video Conferencing Monitor | In Stock | £341.58 |
Dell P2225H 22" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor | In Stock | £88.69 |
Dell P2425HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £165.88 |
Dell UltraSharp U2724D - LED monitor - QHD - 27" | In Stock | £278.61 |
Dell P2725H 27"1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £139.87 |
Dell P2425H 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £119.24 |
Dell UltraSharp U2424HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £209.52 |
Dell UltraSharp U2725QE 27" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor | In Stock | £518.22 |
Dell P2725HE 27" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £186.11 |
Dell Pro Plus P2725DE 27" 2560x1440 8ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £256.26 |
Dell SE2225HM 2" 1920x1080 5ms VGA HDMI LED Monitor | In Stock | £60.56 |
Dell Pro E2425HSM 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £87.77 |
Dell UltraSharp U2724DE 27" 2560x1440 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor | In Stock | £361.32 |
