Dell PRO 16 PC16250 C5-120U 16G/512G W11P
Quicklinx: JDD6WS00 Mfr#: HT0V6
Screen Size: 16in
Processor Model: 120U
Operating System: Windows 11 Pro
Hard Drive Capacity: 512GB
Graphics: Intel Graphics
  • IEEE 802.11n
More than 50 In Stock
£781.91 ex VAT
£938.29 inc VAT
The Dell Pro 16 PC16250 is designed to meet the demands of modern computing with a polished blend of performance and clarity. It features a 16-inch Full HD Plus display with a native resolution of 1920 x 1200, offering vibrant visuals and wide viewing angles for an immersive experience. The anti-glare technology ensures comfortable viewing over extended periods, while IPS technology adds rich colors and sharp imagery. With a powerful Intel Core 5 processor, this notebook delivers reliable performance tailored for multitasking and professional applications. Equipped with advanced features like a dual array microphone and high definition audio, the Dell Pro 16 ensures crisp sound quality for calls and media. The integrated RGB camera provides high-resolution video at 1920 x 1080 and incorporates a shutter for privacy. Connectivity options abound, with multiple USB ports, HDMI, and Thunderbolt 4 ensuring seamless connectivity to peripherals and displays. With the added benefit of ExpressCharge, quick battery replenishment is possible, making this notebook a dependable companion for both work and leisure.
Dell Pro 16 PC16250 - AI PC - 16" - Intel Core 5 - 120U - 16 GB RAM - 512 GB SSD
Notebook - AI PC
Operating System
Win 11 Pro
Intel Core 5 (Series 1) - 120U / 1.4 GHz, up to 5 GHz / 12 MB Cache
16 GB DDR5 (1 x 16 GB)
Storage
512 GB SSD - NVMe
Display
16" 1920 x 1200 / Full HD Plus @ 60 Hz - 141 ppi
Graphics
Intel Graphics
Keyboard Backlight
Numeric Keypad
Integrated Webcam
Bluetooth, 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Gigabit Ethernet
3-cell
Security
Discrete Trusted Platform Module (TPM 2.0) Security Chip
Magnetite
35.8 cm x 25.182 cm x 2.085 cm
1.92 kg
Pricing Type
Build To Stock (BTS)
Manufacturer Selling Program
Dell Smart Selection
Environmental Standards
EPEAT Gold
Carbon Footprint
108 kg carbon emissions
1.45 W/kg (body) , 1.45 W/kg (limb)
Bundled Services
1 Year Basic Onsite
Notebook
AI Level
AI PC
Operating System
Windows 11 Pro
Processor / Chipset
CPU
Intel Core 5 (Series 1) 120U / 1.4 GHz
Max Turbo Speed
5 GHz
Number of Cores
10-core
Performance Cores
2
Efficient Cores
8
Cache
12 MB
12 Threads
RAM
16 GB (1 x 16 GB)
Max RAM Supported
64 GB
DDR5 SDRAM
Speed
5200 MT/s
Rated Speed
5200 MT/s
SO-DIMM 262-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
512 GB SSD M.2 2230 PCIe 4.0 - NVM Express (NVMe)
Display
16" - IPS
Resolution
1920 x 1200 (Full HD Plus)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
141
Image Aspect Ratio
16:10
Image Brightness
300 cd/m²
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+85 / -85
Colour Gamut
45% NTSC
Anti-glare, 35 ms response rate, 0.1795 mm pixel pitch
Audio & Video
Graphics Processor
Intel Graphics
Camera
Yes - 1920 x 1080 (standard), 640 x 360 (infrared)
Resolution
2.07 Megapixel (standard), 0.23 Megapixel (infrared)
Image Sensor Type
CMOS
Video Resolutions
1920 x 1080
Frame Rate
30 frames per second
Camera Features
Face recognition, IR camera, RGB camera, Temporal Noise Reduction, 86.6 degrees (IR camera), 80.2 degrees, camera shutter
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3204
High Definition Audio, Wave MAXXAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Numeric Keypad
Copilot key
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6E AX 211 - M.2 2230
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111H-CG
Dual stream (2x2)
3-cell
210 g
55 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
65 watt, 5 / 9 / 15 / 20 V
Connections & Expansion
Interfaces Details
HDMI , USB-C 3.2 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , USB4 (supports Thunderbolt 4, DisplayPort Alt Mode) (Power Delivery) , USB 3.2 Gen 1 , USB 3.2 Gen 1 (PowerShare) , LAN (RJ-45) , Headphone/microphone combo jack
Software
Software Included
Intel Rapid Storage Technology, Dell Additional Softwares, Activate your Microsoft 365 for a 30 day trial
Magnetite
Surface Finish
Texture
Security
ExpressCharge, ExpressChargeBoost
Theft/Intrusion Protection
Security Slot Type
Wedge-shaped security slot
USB-C power adapter, POD Label
FIPS 140-2, TCG Certified
Pricing Type
1.92 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
Carbon Footprint
Manufacturing (kg CO2e)
70.416
Logistics (kg CO2e)
6.048
Use (kg CO2e)
28.512
EOL (kg CO2e)
3.02
Total Carbon w/o Use Phase (kg CO2e)
90
PAIA Version
GaBi version 1, 2024
Bundled Services
1 Year Basic Onsite
90% (non-condensing)
Shock Tolerance (operating)
140 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
JDD6 Dell DELL PRO DOCK - WD25 In Stock £148.54
JDD6 Dell Pro Smart Dock SD25 - docking station In Stock £206.78
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
JDD6 Dell 1Y BASIC ONSITE TO 3Y BASIC ONSITE In Stock £37.26
Other bundles (28)
JDD6 Dell Slim DW316 USB External DVD Drive In Stock £40.60
JDD6 Dell MS116 Mouse Optical Wired USB Black For Lattitude In Stock £8.69
JDD6 Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 In Stock £12.80
JDD6 Dell Dell KB-522 Wired Business Multimedia USB Keyboard - Black In Stock £23.31
JDD6 Dell KB-813 Smart Card Reader In Stock £45.62
JDD6 Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £25.61
JDD6 Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £44.32
JDD6 Dell SB521A Magnetic Sound bar In Stock £30.78
JDD6 Dell MS5120W Mobile Pro Wireless Mouse In Stock £28.14
JDD6 Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £43.18
JDD6 Dell Multi-Device KB700 - Keyboard - wireless - 2.4 GHz, Bluetoot In Stock £48.55
JDD6 Dell WEBCAM - WB3023 In Stock £47.02
JDD6 Dell Dell Mobile Wireless Mouse - MS3320W - Black In Stock £15.38
JDD6 Dell Dell Speakerphone SP3022 In Stock £67.46
JDD6 Dell UltraSharp 24" 1920 x 1080 5 ms IPS In Stock £157.91
JDD6 Dell 27" P2724DEB 2560x1440 5ms HDMI DisplayPort USB-C Video Conferencing Monitor In Stock £341.58
JDD6 Dell P2225H 22" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor In Stock £88.69
JDD6 Dell P2425HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £165.88
JDD6 Dell UltraSharp U2724D - LED monitor - QHD - 27" In Stock £278.61
JDD6 Dell P2725H 27"1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £139.87
JDD6 Dell P2425H 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £119.24
JDD6 Dell UltraSharp U2424HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £209.52
JDD6 Dell UltraSharp U2725QE 27" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor In Stock £487.37
JDD6 Dell P2725HE 27" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £186.11
JDD6 Dell Pro Plus P2725DE 27" 2560x1440 8ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £259.41
JDD6 Dell SE2225HM 2" 1920x1080 5ms VGA HDMI LED Monitor In Stock £57.96
JDD6 Dell Pro E2425HSM 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £87.77
JDD6 Dell UltraSharp U2724DE 27" 2560x1440 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor In Stock £378.44
Screen Size: 16in
Brand: Dell
Price Range Ex VAT: £750 - £1000
