The Dell Pro 16 PC16250 is designed to meet the demands of modern computing with a polished blend of performance and clarity. It features a 16-inch Full HD Plus display with a native resolution of 1920 x 1200, offering vibrant visuals and wide viewing angles for an immersive experience. The anti-glare technology ensures comfortable viewing over extended periods, while IPS technology adds rich colors and sharp imagery. With a powerful Intel Core 5 processor, this notebook delivers reliable performance tailored for multitasking and professional applications. Equipped with advanced features like a dual array microphone and high definition audio, the Dell Pro 16 ensures crisp sound quality for calls and media. The integrated RGB camera provides high-resolution video at 1920 x 1080 and incorporates a shutter for privacy. Connectivity options abound, with multiple USB ports, HDMI, and Thunderbolt 4 ensuring seamless connectivity to peripherals and displays. With the added benefit of ExpressCharge, quick battery replenishment is possible, making this notebook a dependable companion for both work and leisure.
- Dell Pro 16 PC16250 - AI PC - 16" - Intel Core 5 - 120U - 16 GB RAM - 512 GB SSD
- Product Type
- Notebook - AI PC
- Operating System
- Win 11 Pro
- Processor
- Intel Core 5 (Series 1) - 120U / 1.4 GHz, up to 5 GHz / 12 MB Cache
- Memory
- 16 GB DDR5 (1 x 16 GB)
- Storage
- 512 GB SSD - NVMe
- Display
- 16" 1920 x 1200 / Full HD Plus @ 60 Hz - 141 ppi
- Graphics
- Intel Graphics
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Gigabit Ethernet
- Battery
- 3-cell
- Security
- Discrete Trusted Platform Module (TPM 2.0) Security Chip
- Magnetite
- 35.8 cm x 25.182 cm x 2.085 cm
- 1.92 kg
- Pricing Type
- Build To Stock (BTS)
- Manufacturer Selling Program
- Dell Smart Selection
- Environmental Standards
- EPEAT Gold
- Carbon Footprint
- 108 kg carbon emissions
- Specific Absorption Rate (SAR)
- 1.45 W/kg (body) , 1.45 W/kg (limb)
- Bundled Services
- 1 Year Basic Onsite
- Product Type
- Notebook
- AI Level
- AI PC
- Operating System
- Windows 11 Pro
Processor / Chipset
- CPU
- Intel Core 5 (Series 1) 120U / 1.4 GHz
- Max Turbo Speed
- 5 GHz
- Number of Cores
- 10-core
- Performance Cores
- 2
- Efficient Cores
- 8
- Cache
- 12 MB
- 12 Threads
- RAM
- 16 GB (1 x 16 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR5 SDRAM
- Speed
- 5200 MT/s
- Rated Speed
- 5200 MT/s
- Form Factor
- SO-DIMM 262-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 512 GB SSD M.2 2230 PCIe 4.0 - NVM Express (NVMe)
Display
- 16" - IPS
- Resolution
- 1920 x 1200 (Full HD Plus)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Pixel Density (ppi)
- 141
- Image Aspect Ratio
- 16:10
- Image Brightness
- 300 cd/m²
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +85 / -85
- Colour Gamut
- 45% NTSC
- Anti-glare, 35 ms response rate, 0.1795 mm pixel pitch
Audio & Video
- Graphics Processor
- Intel Graphics
- Camera
- Yes - 1920 x 1080 (standard), 640 x 360 (infrared)
- Resolution
- 2.07 Megapixel (standard), 0.23 Megapixel (infrared)
- Image Sensor Type
- CMOS
- Video Resolutions
- 1920 x 1080
- Frame Rate
- 30 frames per second
- Camera Features
- Face recognition, IR camera, RGB camera, Temporal Noise Reduction, 86.6 degrees (IR camera), 80.2 degrees, camera shutter
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3204
- High Definition Audio, Wave MAXXAudio Pro
Input
- Keyboard, touchpad
- Numeric Keypad
- Copilot key
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6E AX 211 - M.2 2230
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Realtek RTL8111H-CG
- Dual stream (2x2)
- Technology
- 3-cell
- 210 g
- Capacity
- 55 Wh
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 65 watt, 5 / 9 / 15 / 20 V
Connections & Expansion
- Interfaces Details
- HDMI , USB-C 3.2 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , USB4 (supports Thunderbolt 4, DisplayPort Alt Mode) (Power Delivery) , USB 3.2 Gen 1 , USB 3.2 Gen 1 (PowerShare) , LAN (RJ-45) , Headphone/microphone combo jack
Software
- Software Included
- Intel Rapid Storage Technology, Dell Additional Softwares, Activate your Microsoft 365 for a 30 day trial
- Magnetite
- Surface Finish
- Texture
- Security
- ExpressCharge, ExpressChargeBoost
- Theft/Intrusion Protection
- Security Slot Type
- Wedge-shaped security slot
- Included Accessories
- USB-C power adapter, POD Label
- FIPS 140-2, TCG Certified
- Pricing Type
- 1.92 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- Carbon Footprint
- Manufacturing (kg CO2e)
- 70.416
- Logistics (kg CO2e)
- 6.048
- Use (kg CO2e)
- 28.512
- EOL (kg CO2e)
- 3.02
- Total Carbon w/o Use Phase (kg CO2e)
- 90
- PAIA Version
- GaBi version 1, 2024
- Bundled Services
- 0 °C
- 40 °C
- 90% (non-condensing)
- Shock Tolerance (operating)
- 140 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.66 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
Dell DELL PRO DOCK - WD25 | In Stock | £148.54 |
Dell Pro Smart Dock SD25 - docking station | In Stock | £206.78 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
Dell 1Y BASIC ONSITE TO 3Y BASIC ONSITE | In Stock | £37.26 |
Other bundles (29)
Dell Slim DW316 USB External DVD Drive | In Stock | £36.19 |
Dell MS116 Mouse Optical Wired USB Black For Lattitude | In Stock | £8.69 |
Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 | In Stock | £12.80 |
Dell Dell KB-522 Wired Business Multimedia USB Keyboard - Black | In Stock | £23.31 |
Dell KB-813 Smart Card Reader | In Stock | £45.62 |
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £34.22 |
Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey | In Stock | £44.32 |
Dell SB521A Magnetic Sound bar | In Stock | £30.78 |
Dell MS5120W Mobile Pro Wireless Mouse | In Stock | £28.14 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £57.37 |
Dell Dual Monitor Stand - MDS19 | In Stock | £129.07 |
Dell Multi-Device KB700 - Keyboard - wireless - 2.4 GHz, Bluetoot | In Stock | £35.11 |
Dell WEBCAM - WB3023 | In Stock | £47.02 |
Dell Dell Mobile Wireless Mouse - MS3320W - Black | In Stock | £15.38 |
Dell Dell Speakerphone SP3022 | In Stock | £61.06 |
Dell UltraSharp 24" 1920 x 1080 5 ms IPS | In Stock | £157.90 |
Dell 27" P2724DEB 2560x1440 5ms HDMI DisplayPort USB-C Video Conferencing Monitor | In Stock | £341.58 |
Dell P2225H 22" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor | In Stock | £88.69 |
Dell P2425HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £165.88 |
Dell UltraSharp U2724D - LED monitor - QHD - 27" | In Stock | £278.61 |
Dell P2725H 27"1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £139.87 |
Dell P2425H 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £112.94 |
Dell UltraSharp U2424HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £209.52 |
Dell P2424HEB 24" 1920x1080 5ms HDMI DisplayPort IPS LED Video Conferencing Monitor | In Stock | £275.21 |
Dell UltraSharp U2725QE 27" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor | In Stock | £487.37 |
Dell P2725HE 27" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £186.11 |
Dell Pro Plus P2725DE 27" 2560x1440 8ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £247.13 |
Dell SE2225HM 2" 1920x1080 5ms VGA HDMI LED Monitor | In Stock | £60.56 |
Dell Pro E2425HSM 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £87.77 |
